Intel Play QX3 Monocular Microscope Logo
Posted on Sep 21, 2011
I am trying to gey my intel play QX3 to work on my vista computer. What software do I need to download?
David Gutz
Level 1:
New Friend:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Oct 19, 2013
David Gutz
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
11
Questions
0
Helped
29196
Points
12
Http://download.cnet.com/Intel-Play-QX3-Microscope/3000-2110_4-104288.html
worked for me Win 7 64 bit. May need to use compatibility mode (look it up separate problem if that's the case)
5 Related Answers
Mark Mehall
  • 72 Answers
  • Posted on Dec 05, 2008
SOURCE: I need the driver for my Intel Play QX3 for Vista
This works on my Vista system.
Instruction for installing the QX3 Microscope with Vista
Note, DO NOT use the software from the CD that came with the microscope.
DO NOT plug in the QX3 microscope until Step 4.
Step 1. Install the QX3+ downloaded from Intel:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&Inst=Yes&ProductID=160&DwnldID=4419&strOSs=All&OSFullName=All%20Operating%20Systems&lang=eng
Step 2. Download and install the QCODINSTL Codecs software from:
http://www.intel.com/support/intelplay/qx3/sb/cs-016002.htm
Step 3. Download and extract the QX3 Drivers from:
http://hyperslug.s3.amazonaws.com/IntelQX3driverXP.zip
Step 4. Now, plug in the microscope.
When the "Found New Hardware" wizard appears, select "Locate and install driver software (Recommended)", a message "Installing device driver software" will appear. If you click on "details", you will see "Searching Windows Update", after a while you will be able to select "I don't have a disc. Show me other options" and browse to the folder with the extracted QX3 drivers from Step 3. above. The hardware should install successfully.
Double-click on the QX3+ icon on the desktop and the program should run.
Mark Mehall
  • 72 Answers
  • Posted on May 24, 2009
SOURCE: QX3 micrscope dont work with Vista
Uninstall the existing Intel microscope software and then follow the steps below.
Instruction for installing the QX3 or QX3+ Microscope with Vista
Step 1. Install the QX3PLUS.EXE software downloaded from Intel:
Step 2. Download and install the QCODINSTL.EXE software from:
Mark Mehall
  • 72 Answers
SOURCE: vista driver for Intel QX3 Microscope
Mark Mehall
  • 72 Answers
  • Posted on Jul 04, 2011
SOURCE: The software keys into the
Here are the instruction for installing the Intel QX3 (or QX3+) Microscope with Windows 7. You must be using a 32-BIT VERSION. The QX3 is not compatible with 64-bit versions of Windows 7 or Vista.
Before you run the programs below, right click the icon, click on "Properties", click the "Compatibility" tab, check the box next to "Run this program in compatibility mode for:", then choose in the drop-down box "Windows 98 / Windows ME". You should also check "Run as Administrator" if your account is a "Standard user".
Step 1. Download and install the QX3PLUS.EXE software from Intel:
http://tinyurl.com/qx3plus or
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&Inst=Yes&ProductID=160&DwnldID=4419&strOSs=All&OSFullName=All%20Operating%20Systems〈=eng
http://tinyurl.com/QCODINSTL or
http://downloadcenter.intel.com/Detail_Desc.aspx?strState=LIVE&ProductID=160&DwnldID=2089&agr=N&lang=eng&PrdMap=160
http://tinyurl.com/IntelQX3driverXP or
When the "Found New Hardware" wizard appears you will see a message saying that the driver installation was not successful. Click the Close box. You need to install the driver manually by following these steps:
a. Click START - Select Devices & Printers
b. Right-click on the Intel QX3 Icon and select Properties
c. Click the Hardware tab - click Properties
d. Click Update Driver - select "Browse my computer for driver software"
e. Browse to the folder with the extracted QX3 drivers from Step 3. above. The driver software should install successfully.
Mark Mehall
  • 72 Answers
  • Posted on Jul 24, 2011
SOURCE: need vista drivers for QX3
Here are the instruction for installing the QX3 (or QX3+) Microscope with Vista. You must be using a 32-BIT VERSION. The QX3 is not compatible with 64-bit versions of Vista.
or
http://downloadcenter.intel.com /Detail_Desc.aspx?agr=Y&Inst=Yes&ProductID=160&DwnldID=4419& amp;strOSs=All&OSFullName=All%20Operating%20Systems?=eng
I need dowland drivers to intel play model APB 24221 99A
Here are the instruction for installing the QX3 (or QX3+) Microscope with Vista and Windows 7. You must be using a 32-BIT VERSION. The QX3 is not compatible with 64-bit versions.
http://tinyurl.com/QX3-Win7-Files
Before you run the QX3Plus program right click the icon, click on "Properties", click the "Compatibility" tab, check the box next to "Run this program in compatibility mode for:", then choose in the drop-down box "Windows 98 / Windows ME". You should also check "Run as Administrator" if your account is a "Standard user".
Step 5. Now double-click on the QX3+ icon on the desktop and the program should run.
Is there a free download so I can run my Intel.Play Qx3 Microscope in Vista
or
Need vista drivers for QX3. had it on my old win 95 computer, but need to install it on my new vista machine. Are there vista drivers for the Intel Play Qx3 microscope?
or
7helpful
4answers
My QX3 worked wonderfully on my XP system, but I can't load the drivers/installation files on a Vista system.
Sorry, Intel stopped making these years ago. They DID post updated drivers, but long before Vista arrived. Go to the Intel web site, your only other hope is to find a blog of Intel QX3 users, maybe some gearhead updated the driver pro bono.
I have play Qx3 from my friend and i have windows vista and when i tray to make it work my pc say that it cant find all the necessary software components plz reinstall Qx3 software (85) so what can i do
or
3helpful
Have QX3+ driver for my intel play microscope but poses a problem
Uninstall the existing Intel microscope software and then follow the following instructions:
17helpful
2answers
Vista driver for Intel QX3 Microscope
2helpful
2answers
5helpful
10helpful
3answers
Qx3 miroscope
This worked for my QX3 on my Vista computer!
Top Intel Science & Laboratory Experts
ADMIN Eric
ADMIN Eric
Don A
Don A
Collins Mccoy
Collins Mccoy
Are you an Intel Science and Laboratory Expert? Answer questions, earn points and help others
