You can obtain it from any
mobile shop, either from a website like http://blackberryimeiunlockcode.net/ or any other website, on website order your mep code
by entering your imei number & network which your bb locked to.
You`ll get your mep code through e-mail with
in few minutes with instructions of entering the mep code. Just
follow the instructions for entering the code & That`s it your
blackberry has now unlocked & then you can use it with any GSM Sim
card
worldwide. The Website will give you the blackberry mep code as cheaper, as well as much faster (within 1 minute)
than a shopkeeper does. Website also gives you a 100% money back
guarantee if the code does not work. This is the best way to get mep
code for your bb & unlock it from the comfort of your home. Unlocking through code is permanent means it cannot be re lock again itself!!! Click here to get blackberry curve 8520 mep code
Hi,you can unlock your mobile by unlock codes..the safe and best way of unlocking is by unlock codes and my personal request is that don't go for software unlocking because sometimes the software might get corrupted and may your data will be lost due to that,its my bad experience so I went for unlocking by codes from mobileunlocksolutions and unlocked.you can too try but see to that whether your country and provider is listed..because for some service only codes are available..check with that and if your country's provider is listed then get codes and unlock your mobile..
You get your Mep Code for blackberry 8520 curve by this site. read carefully and and get your Mep Unlock Code. i hope this will help you .
Go to this link read that instruction carefully and you will get your mep code.They also have blackberry curve 8520 unlocked to unlock your phone network if you want. But if your chance to entering mep code already zero you can't unlock blackberry unless you doing cable unlocking method. Good luck!
