To Connect Your Phone to Your Computer
In today's world we use mobile phones to all the <b>PC connection</b>, connecting the phone to our <b>PC</b>, we can dial your modem and connect to your ISP, intranet or any other network. In most cases, simply connect your phone to your computer, you can use telephones to the network including the Internet, and services.<br />
<br />
Before you begin, it might be a good idea to contact your mobile provider and ask what services you have available, because some providers do not completely block these services, contact information, and you could be (ie, login, password , etc.).<br />
<br />
<b>BlueTooth: "Wireless PC Connections"</b><br />
<br />
After checking with your phone provider to find out what services you have:<br />
Verify that the Blue Tooth is active and detect your mobile device.<br />
<br />
Blue Tooth Open control panel located on your<b> PC</b>.<br />
<br />
On your <b>PC</b>, select "search phone", then select your mobile device and click the button "Pair."<br />
<br />
Enter a "new" password, then enter "same" password on your mobile device when prompted.<br />
<br />
When prompted on the <b>PC</b>, select the connection type and Internet connection information for your wireless service provider or ISP.<br />
<br />
<b>USB: "Data Cable"</b><br />
<br />
Again, after an adjustment for operator services available to you:<br />
<br />
If you have software that works the phone with the software. You may have to skip the rest of these steps.<br />
<br />
Connect the data cable to the back of the phone and the other to a USB port on your<b> PC</b> or <b>laptop</b>.<br />
<br />
If you are prompted to select the "how" to connect.<br />
<br />
If you do not have software installed on your mobile device let your <b>PC</b>, check if it is unable to install the correct driver.<br />
<br />
It may be necessary to access the device from your computer as a "Drive" and then examine it in a folder ..<br />
<br />
As with all the information I can not guarantee the net this article 100% accurate, or even ensure that the information will not destroy the mobile device when you try to attach it to the Internet. This article was meant to be a brief overview of a typical outreach activities.
This is really easy to fix-- pull the power and plug it back in. fixed!!
