Yamaha Corporation Of America 61 Key YPT410 Portable Keyboard (YPT410MS) Logo
Posted on Aug 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Yamaha YPT-410 When playing the keyboard, the sound cuts out when playing multiple keys, and then begins again only to cut out again. Does not matter which keys. I have done a factory reset and it did not help. It is almost as the sound level goes up and reaches a point the sound stops.
Rabbit Brains
Level 3:
  • Master 575 Answers
  • Posted on Oct 13, 2011
Rabbit Brains
Master
Level 3:
Answers
575
Questions
Helped
182733
Points
1598
It's probably your keyboard. Some keyboards are limited with it's polyponic capabilities. Some can play many notes at one time, some cut out when it reaches it's limits. Check your manual for specifications.
Yamaha YPT 400: ALL re are not working
Hi, If by "re" not working you mean note D then try the following.
Keyboard off, hold down top C key while turning on. This factory resets. Does D key now work - if not. Has it ever worked - if not then it could possibly be the ribbon connector between the keyboard and the motherboard. If one of the cables gets bent then this would stop all notes associated with that connection to stop working. This will only have occured if the keyboard has never played these notes or if it has been taken apart.
You could also try the self test mode : Keyboard off, hold C#,F, G# in the 2nd octave up whilst turning on, cycle through tests to sound if it plays all the notes one at a time then the sound chip is ok and it points to keyboard switching. If test mode does not come up in 2nd octave try 3rd octave ( cant remember which one it is from memory )
Let me know how you get on.
yamaha-ypt-400-all-re-not-working#solution-section-o0etyz1v3mt3zyequ52mc4su-5-2_0.jpg
I have a YPT-310 Yamaha electronic keyboard. I can play it for about a minute and while I press every key the light up panel flashes. After 1 minute of play it turns off. Any ideas on how to fix it?
The problem is in the inside of ypt310,nothing to do from outside.
Is it after the unit is turned off, and then revived, this conditions happen again?
If the unit still can play for a minute/moment, the damage is usually located on the regulator. There may be a capacitor/resistor/ic damaged by heat. When there is not hot, the regulator is working normally, and the unit was normal. But after a while the heat turned up (at component parts), the regulator becomes abnormal / unstable, and the unit is turns off.
There may also be damage in the other section, which causes the regulator gets hot. If you are not experienced in electronics repair, then leave it to the experts.
Try also, check the wiring-connection from regulator to another board (usually using the socket, it may loose its socket)
I have a key that sticks really bad...how do I fix it?
carefully remove the cover of your ypt-320 and also remove the sticky key to check the rubber pad under it .try replacing it.
3helpful
I own a Yamaha YPT-220 portable keyboard. The "c", "b" and "f" keys (all octaves) just stopped producing a sound. Anyone else have this problem?\r\n The dealer's service...
That's the thing with today's electronic and why warranty length is so important. Where did you buy your keyboard? It's strange that they won't fix it if it's still under warranty. My Casio CTK-2100 came with 1 year free service and they fix one key that stopped function in few days. I'm pretty sure Yamaha has the same warranty length. You sometimes have to be very persistent with them though...
I was hoping to find a free download for a yamaha-ypt-300 keyboard but no luck
Try to search for XG midisongs and karaoke files (song extentions should be .mid and .kar) on the Internet. There are lots of free songs out there!
1helpful
2answers
Yamaha keyboard not working
We have a Yamaha keyboard YPT-330 note E and F sharp not working why?
When I power my ypt-300 the LCD lights up and
Press the FUNCTION button till "Local Control" appears and then select it "On".
It appears this may take quite a bunch of presses to get down to the Local Control option.
Refer to your manual around pages 56 and 57 to see the list you step through. Local Control is about 2/3 the way down page 57.
Refer to 59 for the simple instruction toe set Local Control on or off.
You can get a free download of the manual at:
http://www.yamaha.com/yamahavgn/CDA/ContentDetail/ModelSeriesDetail/0,,CNTID%253D62635%2526CTID%253D205000,00.html
Click on the resources tab to get to the download.
Have ypt 400 first c wont play note
This is likely a dirty contact. MANY of these keys use a conductive rubber "pill" that is pressed across a set of circuit traces on a circuit board.
Dis-assemble and clean both the "pills" and the circuit traces with 99% isoprophyl alcohol.
The pills are often under silicone rubber domes that also serve to spring back the keys.
2answers
Yamaha pt300 keyboard. only make loud humming sound. Keys register on monitor when touchedas do change in song etc...but no sound other than humming.
If the unit uses a wall transformer, make sure you have the right unit.
The Yamaha correct ones are branded Yamaha. Use of the wrong one can damage keybooard or be inoperative.
The PT300 did not come up as a valid keyboard. Suspect the number is either YPT-300 or a P-300..
Top Yamaha Music Experts
Paul Bade
Are you a Yamaha Music Expert? Answer questions, earn points and help others
