I have a 1999 Dodge Grand Caravan SE and I don't know how to hook up my new Kicker KS693s... I also have the front speakers to install and I don't know how to get the dash off in order to get to the speakers... Could you please help me?
There are 'solution kits' available for this issue. It involves replacing the tensioner pulley and the idler pulley and installing a double sided belt. They are available from Gates, Continental, and AC Delco at RockAuto at the link. http://www.rockauto.com/en/catalog/dodge,1999,grand+caravan,3.8l+v6,1354069,belt+drive,belt+drive+component+kit,10660
The 1998 Dodge Grand Caravan takes 28" wiper blades on both sides front and a
18" rear wiper. See related links below for more information.
Since there are over 22 different wiper arm attachments, do not buy wipers just
by length only - be sure to lookup exact wiper blade part numbers by vehicle
make, model and year for the brand wiper you decide to purchase. This ensures
correct length AND correct attachment.
The 1998 Dodge Grand Caravan has the most common hook-end wiper arms. See
related links below for installation videos.Also, purchase the replacement blades first
and there will be additional instructions/illustrations on the replacement
packages. Locate and press the tab or button where the wiper blade is
inserted into the hook of the wiper arm and pull wiper blade out of hook.
You may have to rotate and flex the blade to make enough clearance for the hook
to pass through.
The 1998 Dodge Grand Caravan has the most common hook-end wiper arms. See related links below for installation videos.Also, purchase the replacement blades first and there will be additional instructions/illustrations on the replacement packages. Locate and press the tab or button where the wiper blade is inserted into the hook of the wiper arm and pull wiper blade out of hook. You may have to rotate and flex the blade to make enough clearance for the hook to pass through.
it may be the temperature sensor that activates the fans is faulty & needs to be replaced or it could be a loose wire or connection check the wiring & connectors......hope this helps......cheers.
REPAIR MANUALS NOT FREE GO TO AUTO ZONE OR ADVANCE AUTO PARTS BUY A HAYNES REPAIR MANUAL.IT IS A GOOD REPAIR MANUAL FOR HOME MECHANICS, COST $28.00 ITS WORTH IT IF YOU DONT TRADE VECHICLE.IT HAVE RIGHT MANY MAJOR REPAIRS FOR YOUR VECHICLE.
