Tip & How-To about Miscellaneous
How to get maximum production from Vertical Injection Molding machine?
Hi if you are making USB Data cable Plant and using Vertical Injection Molding machine then you should take care of some point.
  1. Proper clean environment: The area of your factory should be clean.
  2. Proper water line: The water line for mould dies should be proper so that they don't get heated.
  3. Material: The material for the product should be as per the machine capabilities to attain the maximum output.
  4. Maintainance: Every machine not only Vertical Injection Molding needs maintenance on a regular basis. If you giving regular maintenance then the machine will keep working through a long time.
  5. Operator selection: The operator of the machine is the key point of production. So try to work with an experienced operator or under the supervision of an experienced person.
By keeping these points you can increase your production and machine life as well.
https://www.technomachinesindia.in/vertical-injection-molding-machine-15-ton-2-side-operation.php
Miscellaneous Logo
why does my peugeot boxer profssional usb port not recognise my mp3 player?
USB cables can distort and not make a proper connection. There are 4 cables in a USB connection. This is direct current (DC) through the 2 outer pins... Red is positive @ 5 volts and black is the other outer connection which is the ground. The other 2 center contacts are for the data link. Try to slightly make the connection tighter by gently squeezing the male connection to make it fit firmly in the device. With NOT to much force!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/eric_5179db65226039e7
2answers
Why is my plant brown?
Many reason could cause it. The water is not getting all the way to the leaf, it gets either hot or cold freeze temperatures at some point during the day, too many toxicity on its environment, lack of nutrients on the water. I try some Basic H from Shaklle first, it been use for decades to increase water absorption on agriculture among many other things, and then if that is not enough, some miracle grow, which is a load of minerals for the plants.
Jan 14, 2013 • Garden
Top Miscellaneous Experts
jws1013
Sulejman Sulejmani
Sulejman Sulejmani
Accurate TV Repair...
Are you a Miscellaneous Expert? Answer questions, earn points and help others
