20 Most Recent
MGA Entertainment Bratz Musical Stars Fold Scooter Questions & Answers
HOW DO YOU UNFOLD A SCOOTER
This is very simple really, just find a lever at the base of the scooter and pull up, while also pulling the handlebars up. Sometime the lever has a lock that you have to pull or unscrew.
1/4/2015 4:35:32 PM •
MGA...
Answered
on Jan 04, 2015
We have a scooter that it will not open..
While the scooter is folded, grab the neck and push it in and down at a slant. You will notice how it sinks in a little, once in and down at the right angle you can pull it open.
6/2/2012 1:00:03 PM •
MGA...
Answered
on Jun 02, 2012
Cannot unfold our Bratz Musical Stars Fold Scooter
Call MGA toll free 1 800 222 4685 and they will walk you through the procedure. You have you put one hand on the slanted bar with the yellow label on it and one hand on the foot board and push in and down at the same time. Push at the same angle as the slanted bar. I couldn't get ours open either so I called the company - Good Luck!
4/27/2009 11:30:46 PM •
MGA...
Answered
on Apr 27, 2009
How can I get replacement
I wrote to the company and this was the response:Thank you for contacting MGA EntertainmentWe are sorry. The product is discontinued and replacement parts are no longer available. We can only recommend checking second hand sources such as ebay or local hobby stores. We do apologize for any inconvenience. Thank You, MGA Entertainment
1/25/2015 11:33:36 PM •
MGA...
Answered
on Jan 25, 2015
How do I get the
Hi, it can be a nightmare i know, but the best thing to use is a steam cleaner you can buy these quite cheap now as using soap and water tends to just spread the dye but using a steam cleaner it lifts the dye out of the carpet and can then be wiped off, once you have done this a couple of times you should have it out, apart from that their isnt much that will shift it.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts
8/25/2010 8:02:57 PM •
MGA...
Answered
on Aug 25, 2010
Battery leaked
Try a solution of baking soda and water. apply it to where the battery leaked and try to clean it that way. after you clean it you might want to get a can of contact cleaner and aspray on all the terminals. You can get this at radio shack. I hope this helps you.
12/3/2008 5:03:34 PM •
MGA...
Answered
on Dec 03, 2008
Atach a stand to a ferguson f2620lvd2
You posted this in the Toy category, likely why this wasn't answered. This TV should have attachment points at the back of the TV ( might be covered by caps). Remove caps if there are any and then you can attach the TV to the stand with screws/bolts
4/25/2024 5:40:59 PM •
Toys
Answered
12 hours ago
Hi I've got a babyweaver
Sounds like you are missing the central support rod or bar that connects the Babyweaver swinging crib to the stand, providing stability and support for the crib. This component is crucial for maintaining the structural integrity of the crib and ensuring safe usage. Here are some steps you can take to address the missing part:
1. Contact the Manufacturer:
- Reach out to Babyweaver or the manufacturer of the swinging crib to inquire about obtaining a replacement central support rod.
- Provide them with details about the missing part and the specific model of the swinging crib to ensure you receive the correct component.
2. Check for Spare Parts:
- Check if the swinging crib came with a user manual or assembly instructions that may have information about spare parts or replacement components.
- Look for any contact information provided for customer support or spare parts inquiries.
3. Online Search:
- Conduct an online search using keywords such as "Babyweaver swinging crib central support rod" or "Babyweaver crib replacement parts" to see if you can find the specific part for purchase.
- Explore baby product retailers, online marketplaces, and specialty stores that offer replacement parts for nursery furniture.
4. Local Retailers:
- Visit local baby product stores or furniture stores that carry nursery items.
- Bring the existing part (if you have one side of the support rod) to help them identify and match the missing component.
5. Custom Fabrication:
- If you are unable to find a suitable replacement part, consider contacting a metal fabrication shop or a carpenter who may be able to custom-make a central support rod that fits your Babyweaver swinging crib.
- Provide them with measurements and details about the required specifications for the part.
3/22/2024 3:29:32 AM •
Toys
Answered
on Mar 22, 2024
I have a new model teddy ruxpin and my 2 year old daughter tripped and dropped him. His lights all come on but his app and sound are not working
It sounds like the drop may have caused some internal damage to the electronics or wiring of the Teddy Ruxpin toy. Here are some steps you can take to try and troubleshoot the issue:
- Restart the Toy: Sometimes a simple restart can resolve minor issues. Try turning off the toy completely, including any power switches or buttons, and then turning it back on again after a few moments.
- Check Battery Compartment: Ensure that the batteries are properly inserted and making good contact with the terminals inside the battery compartment. If the drop caused any displacement of the batteries, it might affect the toy's functionality.
- Inspect for Physical Damage: Carefully examine the exterior of the toy for any signs of physical damage, such as cracks, dents, or loose parts. If there's visible damage, it may indicate internal damage as well.
- Test with Different Devices: If the Teddy Ruxpin toy connects to a separate app or device for sound playback, try connecting it to a different device to see if the issue persists. This can help determine if the problem lies with the toy or the connected device.
- Contact Customer Support: If none of the above steps resolve the issue, it's possible that the drop caused internal damage to the toy's electronics or wiring. In this case, you may need to contact the manufacturer's customer support for assistance. They may be able to provide further troubleshooting steps or offer a repair or replacement option.
Keep in mind that since the toy is relatively new, it may still be under warranty, which could cover repairs or replacements for damage caused by accidents like drops. Be sure to check the warranty information or contact the manufacturer for guidance on warranty coverage.
3/21/2024 2:25:15 PM •
Toys
Answered
on Mar 21, 2024
Fisher-Price J7485 T-Rex stopped moving
Check Batteries: Ensure that the batteries are properly inserted and have sufficient charge. Sometimes, a low battery can cause the toy to stop functioning.
Switch On/Off: Confirm that the toy is switched on. Some toys have an on/off switch or button that might accidentally get turned off.
Connections and Wires: Inspect the wires and connections inside the toy. Loose wires or faulty connections can lead to malfunction.
Obstructions: Look for any obstructions or debris that might be preventing the T-Rex's movement. Clear any blockages.
Reset: If there's a reset button, try pressing it. This can sometimes resolve minor issues.
Contact Customer Support: If none of the above steps work, consider reaching out to Fisher-Price customer support as below.
https://service.mattel.com/us/ContactUs.aspx
2/22/2024 2:51:59 PM •
Toys
Answered
on Feb 22, 2024
