20 Most Recent
Coby CT-P530 Corded Phone (ctp530red) Questions & Answers
Repairing coby cx-cd118 cd player
hi there.
Use a lens cleaner to clean your CD player's
lens properly. Unscrew the top cover of the player
and locate the laser lens, which is located just adjacent to the central disc
drive. ... If theCD player
is still skipping
after the lens has been cleaned, there is likely a hardware problem that needs to be solved.31 Mar 2015
https://www.techwalla.com/articles/how-to-fix-a-cd-player-that-skips
Why does a CD player skip?They don't scratch as easily as vinyl LPs, but I've damaged half a dozen CDs over the years. If a CD is skipping, first give it good clean using a CD wipe or mild soap and water. Dry carefully with a lint-free cloth in a straight line from the centre to the edge. Rubbing in circles can cause more damage.12 Aug 2005Buyer beware: to fix a CD that skips, first try good old soap and water ...www.telegraph.co.uk/.../Buyer-beware-to-fix-a-CD-that-skips-first-try-good-old-soap-an...Search for: Why does a CD player skip?
How do you fix a CD player that skips?Clean the CD if it skips or the player can't read it. Use a clean lint-free cotton cloth and make sure the CD is not scratched. Use a lens-cleaning CD in the player. If you can access the lens without opening the case, clean it with a cotton swab and lenscleaner.12 Jul 2010How to Troubleshoot a CD Player - YouTubehttps://www.youtube.com/watch?v=xAlPb7NBvz4Search for: How do you fix a CD player that skips?
or try this link for more help if you need it.
cd player skips Google Search
Coby phone firmware update
Al firmware updates come with an instruction.
I hope you did read the instruction, before you updated in the first place.
For every update there is a condition, the electronic needs to work perfect and the battery / power supply must be capable of delivering enough power during the whole update process.
When an electronic device is start acting strange, a software update is the worst thing you can try to solve the problem.
If there is an update for your phone, why should I type the instruction here? it is in the package and you should read it before. not when the phone is bricked.
Ctp810
whitch type problem specify first? program memory ......... what massage?
Can i replace a coby
Yes you can replace the coby dvd 224 remote with a new one, all you need to do is to get a replacement remote that looks exactly the same as your old one. You can try out that of a friend before you go ahead in replacing it with a new one. Be sure that the problem is not that the battery of the remote is weak and needs replacement or the sensor on the device you use the remote for and the remotes sensor is not bad before you can replace the remote.
Test the sensor by opening the device to check if the pin that is holding the sensor light is not rusty, if it is, then it is the light you are to replace, check the same on the remote to see if the problem is from the remote, then you replace the sensor light which is the infra red light on both the remote and the device itself.
Hope this information helped you. Thank you for using fixya.
The person is not her
Your microphone may be faulty.
If you can drop it back to where you got the phone they should sent it for repair for you
What is direct marketing?
Hello
Direct marketing is a sometimes controversial sales method by which advertisers approach potential customers directly with products or services. The most common forms of direct marketing are telephone sales, solicited or unsolicited emails, catalogs, leaflets, brochures and coupons. Successful direct marketing also involves compiling and maintaining a large database of personal information about potential customers and clients. These databases are often sold or shared with other direct marketing companies.
for more information visit
http://www.wisegeek.com/what-is-direct-marketing.htm
Hope this helps if so do rate the solution
3/21/2024 10:02:08 AM •
Lands Phones
Answered
on Mar 21, 2024
SONIM XP 3800 VOICEMAIL INDICATOR STAYS ON BUT,NO MESSAGES=?
TRIED POWERING OFF-PROBLEM STARTED 2/WEEKS AGO.
1. First, try resetting your phone by powering it off completely and then turning it back on after a few seconds. This can sometimes resolve minor software glitches.
2. If the problem persists, you can try contacting your mobile service provider and ask them to reset your voicemail on their end. They might be able to resolve the issue from their system.
3. Another option is to manually check your voicemail and listen to any existing messages. Sometimes, even if you've listened to a message, the indicator might stay on. By checking your voicemail and ensuring there are no unread messages, it might help clear the indicator.
If none of these steps work, it could be a more complex issue that might require technical support from Sonim or your mobile service provider. They should be able to provide further assistance. Let me know if there's anything else I can help with!
2/5/2024 4:27:32 AM •
Lands Phones
Answered
on Feb 05, 2024
