20 Most Recent
Waterway 1.5hp Hi Flo Above Ground Pool Pump # Ph1150 6 Questions & Answers
I have a proline de
one pound of D.E. for every 10 square feet of filter area, there should be a data plate on the filter telling you what the filter area is.
I have a proline 1.5hp
Keep trying - It is stuck and will likely break but you have to remove it to change the seal. It is not uncommon to need to replace the impeller when the seal fails since the water gets behind the impeller shaft and rusts the metal causing the impeller to bind. If you still cannot get it free pull the motor thru-bolts and lock the rotor once removed from the motor in a vice. Use a large pair of channel locks to break the impeller free...replace it if necessary.
John
How do I get to the pump seal on my hi-flo water
The impeller threads off the shaft and most likely is right hand threads. You will have to lock or hold the motor to remove the impeller. If you remove the motor cover you might find that the motor has a slot in the end of the shaft or two flat sides so you can hold it with a flat wrench.
The impeller is probably plastic and could break. Get a strap wrench to remove the impellor.
