20 Most Recent
Omron HEM 780 Automatic Blood Pressure with Comfit Cuff Questions & Answers
Why is my omrom hem 780 readings keeps fluctuating up and down
the numbers should move as it's calculating your blood pressure , but once it finnishes the test the numbers should lock in and not change till a new test is made
and somethng thats not in any of these machines manual , allways place cuff in same spot on your arm after rolling up your sleeve i use a freckle as my landmark for this , they dont like to work too well over shirt sleeves
Omron problems
That is most likely caused by the ribbin cable coming loose or going bad at its connection
Irregular readings
I guess you need a new
Omron device. It seems that the monitor you are using has become faulty. Since you confirmed your pulse with your doctor, there is no need to worry.
Omron hem 780 how do I erase the memory
...here's the simple solution from Omron themselves: just turn it on, hold the memory 'down' button until it starts scrolling thru all the past readings, then press n hold the start button until you see three dashes across all displays...this should take 2-5 seconds...enjoy!
