20 Most Recent
iRobot Roomba 570 Robotic Vacuum Questions & Answers
My roomba goes in the same circle over and over
Sometimes this can occur when one of the wheel motor sensors has dirt in it. I have had some success blowing compressed air into my main wheel units. You can disassemble them for cleaning, but it is quite involved.
Irobot roomba 570 brush not spinning
Unscrew and remove the side brush. There is probably a wad of hair and dirt underneath it that's keeping it from spinning. When it's clean, *snap* the brush back on, then screw it into place. If it still doesn't turn, you'll need a new module. Call support: 877-855-8593. Good luck.
Please clean Roomba s brushes warning will not stop
Clean the yellow brush bearings. Then run the Roomba without the dustbin, so that you can watch the brush while the unit is cleaning. Is it turning? If not, call customer support. 877-855-8593. Have your Roomba with you; they will want information from it. Good luck.
How to reset roomba 530
Looking for information on how to reset Roomba in easy steps. Read through the information on the page to learn ways you can access the network settings easily. For help on the Roomba setup process, you can always reach out to the team at our end now. The troubleshooting guide on the website contains information on the roomba setup and login process. Visit our website for help on the Roomba login page issues now.
https://irobotroomba.site/how-to-reset-roomba/
Roomba is limping
Definitely check the yellow casters on BOTH brushes. If too difficult to remove with fingers, pull off gently with pliers. They should be cleaned well and any small debris removed with toothpick if needed.
