20 Most Recent
Hamilton Beach 33956 5-Quart Slow Cooker Questions & Answers
My insert also cracked after only a few months use--no known
This sounds like a manufacturing issue - either due to a bad thermostat (unlikely since the temps would have to get very high) or issues with the kilning of the clay (I would guess a too quick cool down). Call the manufacturer - this should be covered by the warranty.
How do I use the Hamilton Beach Slow Cooker 33956
From the Hamilton Beach website:Q Should I close the clips on my Stay or Go slow cooker during cooking?A We recommend closing the clips only during transport and storage. Closing the clips during cooking will not allow for proper ventilation of steam.
Looking for an owners manual for hamilton beach
(http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man) Here is a link to your manual just scroll down type number for your download to start click save to folder open and read after download...you don't have to put an email address if you don't want to....
My Hamilton Beach slow cooker stopped going to keep warm after time was up, model 33966C
If your Hamilton Beach slow cooker model 33966C is no longer switching to the "keep warm" setting after the cook time is up, there could be a few possible causes:
- The thermostat may be malfunctioning. The thermostat controls the temperature of the slow cooker and if it's not working correctly, it could prevent the slow cooker from switching to the "keep warm" setting.
- The timer may be malfunctioning. The timer controls the cook time and if it's not working correctly, it could prevent the slow cooker from switching to the "keep warm" setting after the cook time is up.
- The heating element may be malfunctioning. If the heating element is not working properly, the slow cooker may not be able to maintain the correct temperature to switch to the "keep warm" setting.
- The lid may not be properly sealed. If the lid is not properly sealed, heat may be escaping and the slow cooker may not be able to maintain the correct temperature to switch to the "keep warm" setting.
It is recommended to try to unplug the slow cooker for a few minutes and then plug it back in to see if that solves the problem. If the problem persists, it may be best to contact Hamilton Beach customer service for further assistance or to have the slow cooker repaired or replaced.
Should the lid be a tight fit or loose
Most crock pots are made of porous ceramic and is relatively brittle. It is glazed on all sides (except the bottom usually), to make it hold liquids without absorption. The lids, usually glass or thermoplastic, sit of top, but do not usually fit tightly as this could crack the crock. Also, it is not a pressure cooker, so you want excess steam to vent. The lid just keeps the heat inside and allows condensation to drip back into the crock, reducing the speed at which the fluids cook off, thus the term slow cooker.
