20 Most Recent
Hitachi RB24EAP 23.9cc 2 Stroke 170 MPH Gas Powered Handheld Blower Questions & Answers
Hitachi RB24EAP engine start but no blow
Check the impeller (on the side opposite the pull starter) to see if it is locked to the drive shaft (in the center of the impeller). The shaft could be spinning but, if the impeller is loose on the shaft, it can't spin fast enough to force as much air through the nozzle as it should.
Oil ratio
I use one of those small 2.6 oz oil containers in a gallon (128 oz) to give a 50:1 mix. If you want more oil in your mix add another container - but it will be more expensive and waste oil.
Hitachi Blower not priming
hi
just because you brought it 4 years ago does not mean it is four years old thats when you first used it the machine itself could be 6-7 years old
anyhoo
it sounds to me that when you stored your tool up last time may be for the winter
there was still fuel left in the carburetor
what happens is any fuel left in the carb will expand in cold weather and when it expands it stretches the diaphragm inside the carburetor
hence as soon as you touch the throttle it will probably flood the engine making it hard to start
i will need the full information on the make model engine size
