20 Most Recent Hamilton Beach Hbp100n30als3 1. Cf Microwave Oven White Questions & Answers
3answers
The clock on my hamilton Beach microwave keeps returning to 00:00 each time I set it.
Clock. 12 hr displays, input time, press START not Clock, that should do it.
3/15/2024 8:12:55 PM • Hamilton Beach... • Answered on Mar 15, 2024
2answers
How do I silence the beep on my hamilton beach microwave
If you live in a place where using your microwave in your own apartment angers other tenants, I say time to move, if it is your roommates, then be next to unit and open when at 1... Otherwise pulling apart to shunt or cover speaker may damage the unit and since you asked here, you likely are not electronic savvy and I would not recommend you learn working on such a dangerous device...
11/6/2023 9:41:09 PM • Hamilton Beach... • Answered on Nov 06, 2023
Silence a hamilton beach microwave. How to
Tips to Silence Hamilton Beach Microwave includes cleaning the interior, placing the microwave on a stable surface, using microwave-safe dishes and containers, repositioning the microwave in an open area with ample ventilation, checking for loose parts, using lower power settings, investing in noise-canceling mats, and checking the exhaust fan. To adjust power settings, start the microwave by pressing the "Start" or "Time Cook" button, ensure the microwave is placed on a level surface, and avoid enclosed spaces. Regular maintenance prevents loose or damaged parts. Source: How to Silence Hamilton Beach Microwave
11/6/2023 9:39:56 PM • Hamilton Beach... • Answered on Nov 06, 2023
3answers
My Hamilton beach microwave won't heat up but everything else works
Hello, Kiesha - There can be several reasons why your microwave oven will not heat up. Read the information here: https://www.partselect.com/Repair/Microwave/No-Heat/ Needless to say, unless you are experienced in fixing microwave ovens or you know someone who is, you will need to find an authorized repair business for Hamilton Beach microwave ovens and take your microwave in for an evaluation for repair. There may be an initial charge for evaluating the microwave for the possibility of repair. If your microwave oven is still under warranty, see the information from Hamilton Beach here: https://www.hamiltonbeach.com/warranty
11/2/2023 5:15:28 PM • Hamilton Beach... • Answered on Nov 02, 2023
I just purchased a Hamilton Beach microwave. The display light is so bright that it hurts my eyes. Is there a way to dim it?
You would have to send it to the manufacturer. I know how but have no schematic to accomplish this. Brightness is controlled by a resistor that limits power to the display. Sometimes it is done digitally and involves reprogramming.
7/25/2023 4:22:25 PM • Hamilton Beach... • Answered on Jul 25, 2023
Hamilton Beach 7108 Microwave. looking for the lock clips for it. Where can I find it and how to install?
You don't Monica. It is far too dangerous and a job for the experts. You won't be able to buy parts yourself. https://www.fixya.com/support/r29874712-repairing_microwave_ovens ..
7/24/2023 5:35:30 PM • Hamilton Beach... • Answered on Jul 24, 2023
Turntable spigget arced & burned black even after wire brush cleaning arcing occurred on Hamilton beach microwave
If the turntable spigot on your Hamilton Beach microwave has arced and burned even after cleaning it with a wire brush, it indicates a potential issue with the electrical connection or the turntable motor. Here are a few steps you can take to address the problem:
  1. Disconnect Power: Before proceeding with any repairs, ensure that the microwave is completely disconnected from the power source to avoid any risk of electric shock.
  2. Inspect the Turntable Spigot: Carefully examine the turntable spigot for any signs of damage, such as burn marks or melted plastic. If the spigot is severely damaged, it may need to be replaced. Contact Hamilton Beach customer support or a qualified technician to inquire about replacement parts and proper installation.
  3. Check the Wiring: Inspect the wiring connections near the turntable motor for any loose, frayed, or damaged wires. If you notice any issues, they should be repaired or replaced by a professional technician to ensure safe operation.
  4. Test the Turntable Motor: The turntable motor may be faulty and causing the arcing issue. To test the motor, you will need a multimeter to check for continuity and proper functioning. However, this requires electrical knowledge and experience, so it's best to consult a qualified technician for assistance.
  5. Seek Professional Assistance: If the arcing issue persists after performing the above steps, it is recommended to contact Hamilton Beach customer support or a professional technician. They will have the expertise to diagnose the problem accurately and perform any necessary repairs or replacements.
6/28/2023 4:40:01 AM • Hamilton Beach... • Answered on Jun 28, 2023
2answers
How to set the clock on hamilton beach 900 microwave
press clock,then the time(0945) then clock
10/9/2022 7:27:26 AM • Hamilton Beach... • Answered on Oct 09, 2022
Hamilton Beach 1.1 Cu. Ft. Black Digital Microwave Oven runs loud all of a sudden and doesn't heat up! Anyone know what to do?
There is no repair parts for your unit. The only economical solution is to replace it. If is new return it
6/15/2022 11:17:43 PM • Hamilton Beach... • Answered on Jun 15, 2022
Why does my Hamilton beach microwave have corrosion and/or rust on the lower left hinge?
I don't have a for sure answer ,but mine has that too. Maybe from condensations when used for long time cooking? I do a lot of 20 to 25 min cooking times.
4/28/2022 4:51:33 PM • Hamilton Beach... • Answered on Apr 28, 2022
Trying to replace the light bulb FIXTURE on my Hamilton Beach microwave.
Haha, I was just editing my previous answer to you, but you deleted it. This new question needs the MODEL! In the link Roz Ah, so we changed from the Cars and Trucks category to Microwave Ovens! My underlying point was that all questions need 'make model (what is is)'. Change my search query to 'make model replacement parts'. This will give you a clue https://www.google.com/search?q=hamilton+beach+microwave+p100n30als3b+parts ..
11/7/2021 10:37:55 PM • Hamilton Beach... • Answered on Nov 07, 2021
My Hamilton Beach microwave comes on as soon as I close the door. I don't touch any buttons. What is causing this?
Defective door interlock. Could be shorted wiring
8/23/2021 8:08:24 AM • Hamilton Beach... • Answered on Aug 23, 2021
2answers
Does my hamilton beach microwave have a reset switch?
No. Microwaves do not have reset switches.
7/21/2021 11:47:36 AM • Hamilton Beach... • Answered on Jul 21, 2021
How do i turn off the sound on a Hamilton Beach HB-P90D23AP-T3B microwave
To mute your microwave, start by checking the control panel. Look closely. The mute function may be labeled as a secondary function of one of the standard buttons. Check these things first:
  • Look for a Sound button. Seriously. It may have been there all along, begging you to press it.
  • Press and hold either 1 or 0. Sometimes manufacturers give these keys hidden, secondary functions.
  • Press and hold the Stop or Cancel button. Like 1 or 0, this key might have a hidden function when held.
Often, pressing and holding 1, 0, Stop or Cancel will either result in turning off the beeping sounds or activating a child lock feature. (Child lock doesn't actually lock the door, but instead locks the control panel so no buttons can be pressed until the lock is removed by holding the button for around three seconds again.) If none of these work, it's probably best to consult the manual. Even if you don't have a Sound button, there is no Mute function denoted as a secondary function or holding a button doesn't do anything, there is still a chance a mute function exists. It could be a button combination or, like on some microwaves, be buried in a submenu that's not at all obvious how to activate.
6/3/2021 5:58:01 AM • Hamilton Beach... • Answered on Jun 03, 2021
Hamilton Beach microwave light bulb for interior is needing replaced ..how do I access the bulb
The outer cover has to be removed to gain access.
3/12/2021 7:25:23 PM • Hamilton Beach... • Answered on Mar 12, 2021
My Hamilton Beach microwave model HB-P90D23AP-ST stopped heating anything ump all the buttons work and the digital display appears normal
high voltage transformer ,hv diode or magnetron might be bad
4/2/2020 9:13:31 PM • Hamilton Beach... • Answered on Apr 02, 2020
I have a Hamilton Beach Microwave Model #EM031M2ZC-X3 that suddenly stopped working. It is one year old
It is not uncommon for some microwaves to quit prematurely. What is generally more likely is the particular outlet it is on could also be faulty. Check the outlet with another appliance, or contact Hamilton-Beach themselves to see if there is a known problem/remedy.
3/20/2020 12:12:16 AM • Hamilton Beach... • Answered on Mar 20, 2020
Hamilton Beach Hbp100n30als3 1. Cf Microwave Oven White Logo
Popular Tags
8 questions posted
Top Hamilton Beach Microwave Ovens Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Hamilton Beach Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Hamilton Beach Microwave Ovens
Most Popular Question
hb p100n30al s3 just shut off screen
  • Microwave Ovens
