20 Most Recent
Simplicity for Children 8994W Crib Questions & Answers
We need a manual for
This
crib is on recall. Take it back to Walmart for a full refund of the
original retail price, no receipt required. Take a printout of the link
below. No problem!
http://www.cpsc.gov/cpscpub/prerel/prhtml07/07307.html
Children have died in these. Please dont become a statistic.
I see you want to use it as a toddler bed and this doesnt
appear to be a concern of the recall. Only use as a crib has been
discouraged. However, I do know that one of my customers returned the
exact same bed to Walmart and got $180 cash.
Please consider taking it
to them so that any future use as a crib will be prevented along with
any injury to a future infant sleeping in it. With $180 you can purchase
a very nice toddler bed, even splurge! Good luck.
I need to know how
Good day
Please try this:
Instructions
Things You'll Need
- Headboard
- Footboard
- 2 Side pieces
- Mattress support
- Allen wrench
- 8 Decorative bolts
- 4 Hex bolts
- Hex wrench
- Line up one of the sides of the
crib with the predrilled holes on the headboard and footboard. Until you
get them attached with the bolts, you may need someone to help you hold
them together.
Insert a decorative bolt into
the predrilled hole in the bottom of the headboard and into one of the
crib's side pieces. Use the allen wrench to screw the bolt in almost all
the way. Do not fully tighten the bolt. Repeat this step in the bottom
hole on the footboard. This will help hold the side into place.
the predrilled hole in the top of the headboard and into the side of the
crib. Use the allen wrench to screw it in almost all the way. Do not
fully tighten the bolt. Repeat this in a top hole on the footboard.
Pull up the metal tabs on the
four corners of the mattress support. The top of the support will be the
side that is flat, and the raised edges should point downward. The tabs
will point up and attach to the crib, allowing the mattress support to
"hang."
Line up the four holes in each tab of the mattress support with the holes on each corner of the headboard and the footboard.
6
Attach the mattress support with
the hex bolts and hex wrench. Ensure that each bolt is attached at the
same level so that the mattress support is even.
Slide the remaining crib side in
between the headboard and footboard, lining up the predrilled holes.
Use the remaining four decorative bolts and the allen wrench to attach
the side.
Tighten the bolts where the sides join the headboard and footboard.
Note: The Simplicity crib can be assembled using an allen wrench and a hex wrench.
I hope this information will be helpful...
Thanks for using fixya..
This crib(simplicity 8994W) was given
This
crib is on recall. Take it back to store for a full refund of the
below. No problem!
Information additional: http://www.cpsc.gov/cpscpub/prerel/prhtml07/07307.html
Unforunatley this crib was part of the product recall due to them being dangerous the company has now gone out of business, please click the links it will tell you what to do:
- http://www.cpsc.gov/cpscpub/prerel/prhtml08/08401.html
- http://www.cpsc.gov/cpscpub/prerel/prhtml09/09260.html
- http://www.cpsc.gov/cpscpub/prerel/prhtml09/09260list.html
Hope helps.
