If both speakers failed at the same time, then I bet you changed a setting on the amplifier. This setting probably has something to do with either:
- the sound input (tuner, CD, tape, aux, etc...)
- the sound output (only if you have multiple possible outputs)
If one speaker failed, then the other speaker failed I would check your speaker wire and the connections on each side of the wire. It is possible that the wires were bumped, and pulled out enough to lose contact, or the connections could have corroded. Either way, this is fixable, just make metal contact and your speakers will be up and running again.
If your speakers started acting weird before they failed, then you may have blown them out, in which case you should buy new speakers.
If none of these situations apply, then your amplifier broke, and you need a whole new system.
I hope this was helpful.
