20 Most Recent Grohe 27207000 Movario Trio Shower Set, Chrome Questions & Answers
Grohe LadyLux kitchen pullout sprayer hose has spring surrounding the hose under the sink and is not retracting properly
there may be an issue with the hose or the weight that is attached to the hose under the sink. Here are some steps you can follow to troubleshoot the issue:
  1. Check the weight: There should be a weight attached to the hose under the sink. This weight is designed to help the hose retract back into the faucet. If the weight is loose or not in the correct position, it can affect the retracting ability of the hose. Make sure the weight is securely attached to the hose and is in the correct position.
  2. Check the hose for obstructions: The hose may not be retracting properly due to an obstruction. Turn off the water supply to the faucet and disconnect the hose from the faucet. Carefully inspect the hose for any kinks or blockages. If you find any obstructions, gently straighten out the hose and remove the blockage.
  3. Check for damage to the hose: The hose may not be retracting properly due to damage. Check the hose for any visible signs of wear and tear, such as cracks or tears. If the hose is damaged, it will need to be replaced.
  4. Lubricate the hose: Over time, the hose can become dry and lose its flexibility. Apply a small amount of silicone lubricant to the hose to help it move more freely.
2/16/2023 2:16:51 AM • Grohe Plumbing • Answered on Feb 16, 2023
3answers
Installing new Grohe cartridge 470800 did not stop tub faucet drip
The often happens when the new cartridge is misaligned. https://www.google.com/search?q=Installing+new+Grohe+cartridge+470800 ..
1/14/2023 12:12:21 PM • Grohe Plumbing • Answered on Jan 14, 2023
Cannot remove the pull out spray hose from the water supply line on a Grohe Ladylux kitchen faucet model 33790.
https://www.guillens.com/GRO/33790.htm
12/19/2022 1:51:52 PM • Grohe Plumbing • Answered on Dec 19, 2022
My grohe drain stopper is not holding in closed position. Is there a solution.
If it is a press and lock style, some of them can be pulled out and adjusted to make for more clearance so the locking mechanism has room to work. If it's the style that uses a pull rod from behind the spout, then the circular nut that holds the pop-up rod into the drain directly under the sink. If that's loose, then it won't allow the pop up to stay in place. Hope this helps
11/20/2022 1:13:44 AM • Grohe Plumbing • Answered on Nov 20, 2022
How to remove bell shaped escutcheon on Grohe Geneva lav faucet
Usually these things seize up and destruction and replacement is the only way. If only plumbers would use a little water pump grease or copper anti-seize, this wouldn't happen. Wrap a rubber glove around the bell and put a couple of layer of duct tape on the channel lock pliers. Not the most clever of shapes are they! https://www.faucetdepot.com/prod/Grohe-20.801.000-Geneva-Lavatory-Widespread-Faucet---Chrome-(Pictured-w-Handles--Not-Included)-2962.asp ..
6/16/2022 1:05:54 AM • Grohe Plumbing • Answered on Jun 16, 2022
Why can't kitchen faucet be switched to steady flow?
I have to rotate mine by the aerator to change flow from faucet.
7/13/2021 6:30:00 PM • Grohe Plumbing • Answered on Jul 13, 2021
4answers
How do I fix slow drain brand new plumbing?
The drain pipe may not have been installed correctly - the slope may be wrong, or the pipe may be too small, or you may have too much backpressure, or if you have a septic tank it may be full and need pumping, or any number of other possible problems. You might have another plumber come for an assessment and opinion - make it clear that you don't necessarily intend to hire them to do any WORK, you just want their opinion. Then they won't try to sell you all new plumbing to replace what you just bought...
9/3/2020 11:16:51 AM • Grohe Plumbing • Answered on Sep 03, 2020
How do I tighten my Grohe kitchen faucet to the counter?
use an articulated wrench
5/9/2019 7:59:47 PM • Grohe Plumbing • Answered on May 09, 2019
Cant take of handle of grohe single handle cant find set screw
There is a set screw (blue) behind a removable plug (yellow). g1-jvxqrtzcikl5lzaimxvbkyjf-5-2.png
3/27/2019 11:12:04 PM • Grohe Plumbing • Answered on Mar 27, 2019
I have a single handle Grohe bathroom faucet and I cannot get the handle to uncouple from the faucet to replace the cartridge. I have removed the set screw. Any ideas?
Corrosion/hard water scale has built up between the slotted shaft and the handle .... "cementing" it in place. A faucet handle puller may help depending on your design. This video shows how for a 2 faucet sink setup...but your 1 faucet handle should be similar. The puller will ONLY work though if you can access the end of the slotted shaft to get leverage from. Can you remove an end cap from the handle to access the shaft? ... If the puller will not work .... You could try penetrating oil (if you can get the oil to the corrosion) ... or if your handle is metal, cover it with a wash cloth to prevent marring and tap with a brad hammer. Sometimes that breaks the corrosion bond. You could also try heat/cold/heat/cold by heating with a hair dryer followed by a bag of ice water and then repeat. The temperature cycling might help. In a real pinch ... but you have to VERY careful ... use a pry bar between the escutcheon plate and the handle...go slow .... use cloth protection to prevent marring ... move the pry bar around and rock it....say at 12, 3, 6, 9 o'clock positions around the handle AND .... when you are successful ... when you reinstall ... put some silicon plumbing grease on the shaft to prevent future corrosion!
2/6/2019 10:03:49 PM • Grohe Plumbing • Answered on Feb 06, 2019
My Grohe kitchen faucet is leaking (spray pull-out). Where do I start?
google this you might find the answer or ask jeeves
11/20/2018 6:22:39 PM • Grohe Plumbing • Answered on Nov 20, 2018
Kitchen faucet makes high pitch noise and only a little water comes out. It is a pull out Grohe faucet with a hand sprayer. The amount of water that comes out varies. Water pressure is limited.
You usually can un-screw the hand sprayer, hold on to the hose! If there is more water coming out of the hose then you might have a plugged screen right inside the removed end or the total head is filled with hard water minerals. CLR at Walmart does desolve scale.with out hurting parts.
11/14/2018 5:34:41 AM • Grohe Plumbing • Answered on Nov 14, 2018
My grohe faucet is stuck on the stream spray and won't toggle back to normal water flow. I have the single faucet pull down.
Try to soak the head in white vinegar. Pull the head out and dangle in a glass full of vinegar overnite.
10/7/2018 7:58:53 PM • Grohe Plumbing • Answered on Oct 07, 2018
I replaced a Grohe 47040 cartridge with a grohe 47111 cartridge and the water output is either all hot or all cold
Call the manufacturer for a new one. It should be under warranty.
12/30/2017 7:50:35 PM • Grohe Plumbing • Answered on Dec 30, 2017
My grohe ladylux 3 leaks between hose and sprey head,how do I fix it
Replace the rubber washer between hose and head.
11/18/2017 8:15:54 PM • Grohe Plumbing • Answered on Nov 18, 2017
Our contractor just installed a new Grohe LadyLuxe kitchen faucet, and the arm is very stiff. He lubed it, but it tightens up immediately.
If the new faucet is not acceptable it should be repaired or replaced. It should still be under warranty.
10/11/2017 9:33:20 PM • Grohe Plumbing • Answered on Oct 11, 2017
Grohe Eurodisc pullout won't pull
Strong pair off cutters will do it .
7/12/2017 5:35:44 PM • Grohe Plumbing • Answered on Jul 12, 2017
How to repair a Grohe ladylux cafe touch kitchen faucet which comes on by itself without touching it
Most likely you will need to replace it.
6/8/2017 6:32:27 PM • Grohe Plumbing • Answered on Jun 08, 2017
Grohe 27207000 Movario Trio Shower Set, Chrome Logo
2 questions posted
Top Grohe Plumbing Experts
john h
vince
Paul Carew
Are you a Grohe Plumbing Expert? Answer questions, earn points and help others
View Most Popular
Grohe Plumbing
  • Grohe Plumbing
Most Popular Question
grohe ladylux kitchen pullout sprayer
  • Plumbing
