20 Most Recent
Philips DECT 6.0 Phone with VOIP Questions & Answers
Red light
You didn't specify the model of your Philips DECT 6.0 phone but if I had to guess I'd say you have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Where can i find the positive sign
The same place you find the negative sign. Both "-" and "+" are simply punctuation, inserted into phone numbers for readability. Ignore them and dial just the digits.
I lost my manual for
There should be a button on the machine labeled greeting or record or abbreviations of those words.Press and hold the rec or greet button.It should prompt you when to start speaking,if it does not then just speak your message after the beep.It should automatically play back for your approval.Good luck!
Phillips dect 7272S/05
Here is the link to direcly download pdf manual for your phone:
http://www.p4c.philips.com/files/d/dect7272s_05/dect7272s_05_dfu_eng.pdf
Philips CD130 flashing 'Warning'
You need to dry it out completely. A few centrifugal swings around your shoulder might remove much of the water. Then try one of these drying methods: Place it on a register or AC vent for a day or so might be the best way to get it dry.
Afterwards, (if trying to operate it didn't short out a component,) it might work again.
