20 Most Recent
Saitek Eclipse II Questions & Answers
Saitek Eclipse II Lighted Keyboard
Changing the default colour involves a little dis-mantling.
remove the screws from the back of the board. Carefully remove the rubber feet inserts too as there are 4 more screws under there.
Now remove the top section of the keyboard (the bit with the keys)
Lay the board down flat and you will notice where the usb cable comes in a circuit board. this has a connector with 4 wires attached to it on the left hand side. the wires are coloured red, grey, blue and black. Remove the connector and swap over the Blue and Red wires.
Re assemble the keyboard after reattaching the connector to the circuit board being VERY careful not to overtighten the screws.
Now at boot up the keyboard will by default be red.
Is their any easy way to replace keys whose
A company smartkeyboardsolutions.com has a very high quality label set for laptops or desktops. I bought some myself and they still look new. I also got some in large letters.
Ok when i hit the number 1 key i get `1 that and
Your Keyboard keys is just dirty inside ; try opening it up and cleaning it up -- the circuits and touch detection underneath they key could just be misdetecting the "`" on the left of the "1" key and "2" key
I have to press the space bar right in the middle
Hi!
I had the same problem when i got the keyboard. In my case, it was because the tiny metal bar that is supposed to transfer the pressure from the right and left sides of the bar to the mittle was not attached correctly.
I removed all the screws from the back of the keyboard (note that there are screws underneath the rubber pads, but don't worry about them, they will stick to the keyboard again) and lifted off the top (including the keys). Then i could pop off the space bar from behind (didn't work for me otherwise... maybe it is possible to pop it off without removing all the screws) and correctly insert the metal bar into the mounting.
Hope this helps.
Saitek Eclipse Keyboard Keys stopped working
this could very well be your OS as much as your keyboard. Try another board for a few days and see if it still happens. IF not...you found your culprit. Replace the keyboard or look for updated drivers if they exist.
The " T " and the " Y " require more pressure
what kind of keyboard are you using?? is it from a laptop or pc? if it is an external keyboard, try to detatch the y and t keys from the keyboard using anything that is thin (eg. knife, pen, etc.). clean it... and put it back by just pushing it back..
Saitek Eclipse II keys are sticking
You can remove the screws on the back and clean the keyboard. It's very easy task to do. Just remember components locations inside so you can reassemble.
Wizard cannot find software
hello to who speaks with me.i tried to download pitchers off my phone,unsuccessful,that my computer does not recognize both of my phones.what could i do for my computer to except them?
