20 Most Recent
LG Ku990i Viewty Questions & Answers
Lg fb163-how to add bluetoth function
To add Bluetooth functionality to your LG FB163, you can use a Bluetooth adapter that is compatible with the device. Ensure that the adapter you choose is compatible with the FB163 model. Once you have the adapter, follow the instructions provided with it to connect it to your FB163 system.
To connect your Android phone to the FB163, you'll need a compatible cable. Typically, you would use an auxiliary (AUX) cable with a 3.5mm jack on both ends. Plug one end into the headphone jack of your Android phone and the other end into the AUX input port on the FB163 system. Then, select the AUX input mode on the FB163 to hear the audio from your phone through system.
How can I hatd factory hard reset my LG 265 if I don't have my pin # nomore or forgot it .
- Turn the phone off.
- Press and hold the Power/Lock key (on the right side of the phone) and the Down Volume key (on the left side of the phone) at the same time.
- When the Factory data reset screen appears, release both of the keys.
- Use the Volume keys to highlight Factory data reset, then press the Power/Lock key to confirm.
- Use the Volume keys to highlight Yes, then press the Power/Lock key to confirm one more time.
- Your phone will perform a factory reset.
Im locked out of my
WARNING : Performing a hard reset will remove ALL data including the Google account, system data, application data, application settings, and downloaded applications.
- With the phone off, press and hold the Home key, Volume Down key and Power button. When the LG logo appears, release only the Power button.
- Release the Home key and Volume Down key when the Android icon appears.
- Follow the on-screen instructions.
Can an LG Stylo 4 with a cracked screen , showing only a black screen be repaired so i may extract data from it ?
It is possible to repair an LG Stylo 4 with a cracked screen that shows only a black screen to extract data from it. However, the success of the repair will depend on the extent of the damage to the screen and other internal components.
You can take your device to a professional phone repair shop and ask them to repair the screen. Once the screen is repaired, you should be able to access your data on the device. If the screen repair is not possible or too expensive, you may be able to extract data from the device by connecting it to a computer with a USB cable and using a data recovery software.
Note that data recovery software may not be able to recover all the data from the device, especially if the device has suffered significant damage. It's always a good idea to regularly back up your data to avoid losing important files in case of accidents or device failure.
Lg classic flip phone wont call out or text voicemail now diff carrier
If your LG classic flip phone is not able to call out or send text messages, there could be several reasons for this issue. Some of the common causes are:
- Network Coverage: If you have recently switched to a different carrier, it is possible that your phone is not receiving adequate network coverage in your current location. Try to find a location with better signal strength.
- APN Settings: It is possible that the Access Point Name (APN) settings on your phone are incorrect for the new carrier. Contact your carrier to obtain the correct APN settings and update them on your phone.
- Phone Settings: Some phone settings, such as the network mode, may have changed during the switch to the new carrier. Verify that the settings on your phone are configured correctly for the new carrier.
- SIM Card: The SIM card may have become damaged or is not compatible with the new carrier's network. Try inserting a new SIM card from the new carrier.
If none of these solutions resolve the issue, it is recommended that you contact the new carrier for further assistance. They will be able to diagnose the issue and provide a resolution.
I have an lg sound bar ( las350b) and s-protec shows on the display and I can't use any other function, I turned it off and on and now emergency update mode shows and still I can't do anything.
No part needed. On your mobile phone, search for the music flow bluetooth lg apk, download and install it. You need to do it this way since the app has been discontinued from the Android App Store. Put the device in BT READY mode, it should still let you. Then open the app, press the HELP button then go to Connection problem resolution, your device should pop up here. When you select it it will tell you that the firmware is not supported any more and needs updating. Follow the instructions on screen to update it and you are done.
I fixed a LG LAS305B soundbar this way after translating a forum in spanish. This is the one that found the fix: https://www.yoreparo.com/es/audio/home-theater/preguntas/6107507/sound-bar-modelo-lg-las350b-problema-emergency-update-mode
This issue is super suspicious if you ask me. You could almost conclude that LG bricked your device intentionally.
Hope it will help someone out there. I will post this response whereever i find this issue online.
