20 Most Recent Whirlpool GEX9868J Electric Dryer Questions & Answers
The drum stopped spinning on
send the model number also you don't go into the dryer from the back,you go from the front.
1/2/2018 11:06:08 PM • Whirlpool... • Answered on Jan 02, 2018
Model gew9868KQ2 wont start E7 code
How do you remove the Toe panel off of the Senseon Electric Dryer?
12/12/2012 11:24:47 PM • Whirlpool... • Answered on Dec 12, 2012
Kitchen aid gas dryer lights up but won't start
What is the model number? Look inside the door jamb.
10/20/2012 10:58:48 AM • Whirlpool... • Answered on Oct 20, 2012
The machine doesn't turn, but it just click
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
9/10/2011 4:38:14 PM • Whirlpool... • Answered on Sep 10, 2011
Dryer does not work
Dryer just beeps, lights work, panel lights change, dryer just wont start. before this dryer worked but kept beeping thru the whole cycle. now nothing but lights.
8/6/2011 4:21:49 PM • Whirlpool... • Answered on Aug 06, 2011
Dryer comes on without turning the start knob.
start switch needs replaced. Tim
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
4/24/2011 4:00:39 AM • Whirlpool... • Answered on Apr 24, 2011
My Whirlpool just quit it just won't turn on was
When most Whrlpool dryers do not turn on at all. The most common cause of failure is the door switch and the door switch actuator.
Here is how you can test this.
1 Empty the dryer of clothes
2 Locate the door switch actuator. it will be over along the top edge of where the door closes, just inside the lip. There will be a little (3/8th inch wide) metal tab covered in plastic. The is the actuator the is mounted to the electrical door switch. The door switch is a valuable safety device that prevents children, pets and adults from loosing limbs and other things in a spinning dryer. DON'T BYPASS IT.
3 The tab may simply be broken off. If you can push the piece and hear a clicking sound, it means the switch is probably good but the tab is not.
4 To test this push the tab in or jam a ball point pen in there until it clicks, turn the dryer timer on and push the start button. It it comes on, that was the issue.
WARNING: NEVER, NEVER, NEVER PUT YOU ARM INTO A SPINNING OPEN DRYER DOOR.
JUST DON'T DO IT. IT CAN RUIN YOUR DAY.
5 If you push the tab and get no click but a sort of springy action. The switch is broken.
Usually the switch replacement kit has both the metal tab and the switch.
That is usually it.
If you can supply me with the model number of the dryer, I can help you locate the right part and give some instruction on how to do it.
Hope this helps,
Best Regards,
Mark
1/5/2011 4:44:46 AM • Whirlpool... • Answered on Jan 05, 2011
My whirlpool GEX9868JQ will not
heatman101
9/30/2010 12:09:51 AM • Whirlpool... • Answered on Sep 30, 2010
I have a Whirlpool GEX9868JQ0 Electric dryer.
The electronic control detected that the thermistor is open as indicated by the fault code E1. It's either the connection between the thermistor and the electronic control is broken or the thermistor is indeed open. Troubleshooting and repair is an easy task can be one in a couple of minutes. Make sure to unplug the dryer before attempting any repair work.
Remove the dryer's back panel to access and check the thermistor. Remove the screws securing the back panel then pull the panel off the cabinet and locate the thermistor on the blower housing.
Check to make sure the wires are snugly connected and there are no signs of bad contacts or corrosion. Disconnect the wires if there's no issue found with them and the connections then tape the wires together or jump a wire between them.
Put a few load of wet or damp clothing, plug the dryer in then start it. Error E2 should appear on the display to indicate that the thermistor has been shorted. It signifies that the electronic control and the wire harness are all good and the thermistor is indeed open. Replace the thermistor with part number 8577274.
Simply unscrew it from the blower housing, install the new one, and transfer the wires from the old to the new one. It actually doesn't matter to which terminal the wires should go since the thermistor is not polarized.
Feel free to update us about the development of the troubleshooting and repair should you have further questions.
Note: This advice is outlined for the purpose of troubleshooting without the use of a volt-ohmmeter. Simply check the resistance of the thermistor if a volt-ohmmeter is available. Refer to the table below for the correct resistance reading.
9/2/2010 2:23:51 PM • Whirlpool... • Answered on Sep 02, 2010
My whirlpool gold electric dryer
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back of the machine and try to
locate the air duct going from the blower to the drum. Normally inside the air duct you will find
the heating coil and the thermostats/thermistor. Once you have located the heating coil, remove
the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it
is faulty. If the heating coil is ok, then: You can check the thermostat/thermistor by removing
the two wires and taping them together with electrical tape. If the coil heats up then replace
the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause
a fire, as you have removed the safety of overheat from the machine.
Good Luck, Hope this helps
Please do not forget to rate me, Thank you
8/11/2010 1:40:49 AM • Whirlpool... • Answered on Aug 11, 2010
Drum squeaking noise
Your dryers uses rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley your dryer has a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Rear drum bearing assembly does not fail often in this type of dryer. There are videos of the testing and replacing of these parts at http://appliancehelponline.com/dryerrollervideo.html this will walk you thru the troubleshooting and replacement of these parts Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. This brings us to the last problem could be the blower wheel, which is usually plastic, may wear out over time.To check this grab the wheel and see if theres any play . But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you need to replace it. If you need diagrams or illustrations of your specific model you can also enter your model # there. All parts come with installation instructions. Not all models are available.
6/8/2010 7:32:36 PM • Whirlpool... • Answered on Jun 08, 2010
Stuck in sensing mode
Replace electronic sensor
9/13/2009 11:37:55 AM • Whirlpool... • Answered on Sep 13, 2009
Dryer starts when it wants too
you maby have a weak thermal fuse.
3/15/2009 2:19:33 AM • Whirlpool... • Answered on Mar 15, 2009
Whirlpool GEX9868J Electric Dryer Logo
24 questions posted
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Dryers
  • Whirlpool Dryers
Most Popular Question
whirlpool just quit just turn
  • Dryers
