20 Most Recent
StarTech.com VideoView ST124 (65030772815) KVM Switch Questions & Answers
Trying to set up 3 monitors in windows 7. using on
Sometimes it is difficult to answer a question without asking very basic questions. Using a DVI and a VGA ports will allow you to have screens with different things showing on them. If you use a splitter, the two monitors connected to the splitter will show the same thing on both screens. Is this what you want? I use a splitter at church to have Powerpoint on the main computer monitor, the program then shows on the screen on the wall and the TV monitor, as well as the second monitor at the computer. My splitter occasionally acts up, and I found that unplugging it and plugging it back in makes it work for another couple months. But a splitter for only two monitors is very cheap, no switch box involved.
I have a Hp Laserjet p1505 printer. I installed
Using the Settings Feature on your operating system; you need to make certain the printer is listed and it the main printer to send data to. Check all settings and make certain, if using a wireless connection that the wireless settings are managed correctly. Generally, this is covered in the printer manual. For best results, get the FREE updates, and diagnostic programs from HP.COM.
My Saturn 2001 wagon start for 2-3 sec and turn off
Sounds like a fuel problem.... make sure the theft light is out.... happens when you get a new battery, key or keyfob and that is a dealer problem..... first check fuse for fuel pump, then fuel filter then last pump
No driver
just pull out your sound card and search for a number on it and then search on the net. you will find that.
If this does't help you, tell us the number, we will do this for you.
