20 Most Recent
Polaroid I739M Digital Camera Questions & Answers
Comes on to the polaroid screen but can't take pics or turn off
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Polaroid i739 turns on then off
If the camera has recently been dropped you may have lens damage that's
preventing it from powering up. If it hasn't been dropped your
problem
may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera - which can
prevent the full power of the batteries from flowing into the camera.
Try this free fix before you do anything else: remove the batteries and
wipe the camera contacts firmly with
a dry cloth (heavy corrosion may require cleaning with a wire brush,
steel wool, or sandpaper). Remove any residue that may have fallen into
the battery compartment during cleaning, then clean
the battery contacts, place the batteries back in the camera and give them a full
charge (assuming that you're using rechargeable batteries). This
cleaning clears
the problem about 80% of the time. If it doesn't work for you, it may be time to replace the batteries,or the
camera may have
a problem that requires professional repair.
Batteries
This might be a case of the defective batteries (though brand new). Most if not all rechargeable batteries including Li-Ion batteries have only so much shelf life. The unit might be new but have been with the dealer for sometime.
Probably your best bet would be to bring it back to the dealer and ask for a replacement camera or at least the batteries. Show him the fully charged indicator and how quick it will be gone when you try to take a pic.
Of course, you would need your warranty card, proof of purchase and any other documents normally asked for complaints like this, Hope this give you an idea. Good luck and kind regards.
Camera not working
Unfortunately, if the batteries have corroded then the chances are extremely high that the contacts (and possibly more of the camera's internal electronics) have also been affected by corrosion. It may be possible to clean the contacts yourself, but if there is corrosion internally then the camera is probably not economically repairable.
Polaroid iD1660 not accepting memory card
you dont say what size or type of card you have there? did you previously use the card elsewhere? format the card on a PC using SDFORMATTER (google it) hope that sorts.
Delete amazon account
A factory reset will restore your Kindle to factory conditions and removes any content you've downloaded to your device, be sure to back up your personal content to your computer first. You will be able to download all your Amazon purchases from Archived Items after registering a new device or application.
To factory reset your Kindle:
1. From the Home screen, press Menu.
2. Select Settings.
3. Press Menu again and select Reset to Factory Defaults.
Your Kindle will then begin to reset. This may take a few minutes to complete.
