20 Most Recent
Paragon 1911-8 Popcorn Maker Questions & Answers
Sealed pot lid
Heat the pot again -- the positive pressure inside will break the seal and allow the lid to come off.
After clening the kettle it blows breakers
You got the Heat element and or thermostat wet. Open the kettle to expose the electronics and let it dry for days. try again it might dry out. Or you will need to replace the heat element, thermostat, and probably the wires. if it hasn't dried out by now.
Will not get hot enough
sounds like a burnt element , to check this you need to remove the inner pan from the outer case, they're is a coil inside of it, check for continuity with a test lead at both ends, if thats ok,, you have a thermostat issue
Cooking Pot Return Problems
I use an old heavy 3-quart alumnium sauce pan with a loose-fitting lid, canola oil, and high heat with about 1/2-cup of standard grocery-store yellow popcorn. I get the empty pot nice and hot, add the oil, then the corn, then the pot lid. I shake it occasionally, but basically let it go until the lid starts to rise off the pot, and I don't hear any more pops. Pour it into a large bowl, toss it with very fine sea salt, and go to town! It's also fantastic made with bacon fat, but you need to use slightly lower heat to keep it from burning and prepare for visitors: The smell of popcorn and bacon fat draws crowds.
Wearever pots pans repairs
This is the wrong paragon. Paragon popcorn machines have only been around for approx 15 years. They were GMI prior, and did not make pots and pans.
Maplin N20FR - damp test meter. I have no
N20FR - Used to measure the moisture level in sawn timber (also cardboard, paper) 6 to 44% on the left hand scale and hardened materials (plaster, concrete and mortar) 0.2 to 2.0% on the right hand scale
4/14/2024 9:12:34 PM •
Kitchen...
Answered
on Apr 14, 2024
