20 Most Recent
Prima CV1311 TV Questions & Answers
I need code for remote to turn tv on and change
Most universal remotes brands have some sort of web presence. Try searching your particular remote and look for the brand TV you are trying to control then write it directly on the remote. Better fix would be to go buy a new one. Less than $10. Get the super jumbo one you can't possibly lose!
Prima model number cv1311 will not power up
good day. there are some parts to be tested. just resolder all pins of jungle ic. make sure that the board has no loose connection, try to check them all. then try to on your tv.
Our remote control got damp and no longer works.
These are simple to take apart and you will need to do that to remove the keypad and dry the PCB and rubber feet at the back of the keypad. Do not use an abrasive cloth on the rubber or PCB, just dry it with a light lint rag and it should work fine.
It could take many hours before I can open my
I am having the same problem with our prima lcd tv.I contacted an expert who said we just needed a new power supply board which is about 35 dollars.The only problem is is that Prima is no longer in business and am unable to find anyone who can find part numbers for this brand and their phone number is disconnected and their web site is as well.Sorry I can't be of more help.
Multi color lines in right corner from top to
Unfortunately, what you're describing is a repair issue. You won't be
able to address the problem with troubleshooting. There is a part
inside the TV that needs to be replaced. If you're under warranty,
this will cost you nothing. If you're not under warranty the cost
will likely be a minimum of $200 parts and labor. However, be warned
that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information
allows you to make an informed decision as to how to proceed from
here. Please be sure to vote on my response. I hope I've earned a
good rating from you today.
Please post a comment if you need
additional assistance so that I can help you further.
Tv power will not come on.
Check Fuse if you inclined to open the cabinet, there is a fuse right next to a large cap size looking unit, see if its has foggyness to it or its burned, go to radioshack and request the right polarity and amps or you could blow the main psu. Good luck Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Replacement of fuses on Philips 37PF7320A 37 in. HDTV-Ready LCD
Is the fuse in the plug okay?
If the fuses are not blowing when you are turning the tv on, this suggests that the PSU primary side is okay.
Since you have opened the TV up, I would suggest probing around with a multimeter however I do not want to let you harm yourself or the TV.
Look for any:
http://en.wikipedia.org/wiki/Capacitor_plague
on the power supply
Prima TS2733
i have a prima ttv2131 which locked as above and holding down the display button for five seconds unlocked it (as well as locks it)
Prima Tv problems
some of the tact switch of your tv are defective,or stock ,if you know how to solder, change all switches but be carefull of short circuit
Tv is sparking and making noise?
Warning: Flyback Transformer Failure. ( extreme high voltage ) 22,000 Volts +
Do not attempt to fix this without another human being present who's trained in CPR.
Thank you for choosing FixYa!
Azkeyz, Wizard Division.
