20 Most Recent
Star Logic (11004998) (Black) 15 inch LCD Monitor Questions & Answers
Black flickering line vertickally through monitor screen
It could be either of these:
You're monitor is dying and you need a replacement (Starlogic brand is notorious for dying early and giving poor performance)
You're graphics card is going out. If you have an extra monitor laying around, take out the Starlogic one and plug in the other to see if the same results occur, if not, it's the Starlogic monitor, if the problem still persists, you need a new graphics card or need to update your current drivers.
Star logis 15 inch monitor
Try connecting the monitor to another computer and see if it has the same problem. If so, sounds like part of the display has gone bad. If it is still under warranty, try to get it repaired/replaced. If it's not under warranty, you might be better off getting a new monitor rather than trying to get it fixed, but it doesn't hurt to ask.
H5 ERROR CODE IN BLUE STAR SPLIT INVERTER AC
The H5 error code in a Blue Star split inverter AC typically indicates that there is a problem with the outdoor unit. The outdoor unit is the part of the air conditioning system that is located outside the building and is responsible for releasing the heat absorbed from the inside of the building to the outside.
There are a few possible causes of the H5 error code:
- The outdoor unit's compressor might be malfunctioning. The compressor is the most important component of the outdoor unit and is responsible for compressing and circulating the refrigerant.
- The outdoor unit's fins might be dirty or obstructed. The fins are the thin metal blades that are responsible for releasing the heat absorbed from the inside of the building to the outside. If the fins are dirty or obstructed, the heat exchange process will be impaired, resulting in the H5 error code.
- The outdoor unit's fan motor might be malfunctioning. The fan motor is responsible for turning the fan blades that circulate the air over the fins. If the fan motor is not functioning properly, the H5 error code will be displayed.
To troubleshoot the H5 error code, you should start by checking the outdoor unit for any visible signs of damage or obstruction. If you do not see any obvious problems, you may need to call a professional HVAC technician to diagnose and repair the issue.
I want to know th distance between th earth and a star for exemple? sorry, i'm not very good in english . i'm french . thanks!! :
It depends which star.
Interstellar distances are measured in light-years, which is the distance that light travels in 365 days, about 9.46 trillion kilometres (9.46 x 1012km)
The closest star to Earth is Proxima Centauri, 4.2 light-years away
https://www.space.com/18090-alpha-centauri-nearest-star-system.html
The furthest galaxies are more than 13 billion light years away The furthest individual star sighted is 9 billion light-years
https://en.wikipedia.org/wiki/List_of_the_most_distant_astronomical_objects
Cela d?pend de quelle ?toile.
Les distances interstellaires sont mesur?es en ann?es-lumi?re, soit la distance parcourue par la lumi?re en 365 jours, soit environ 9,46 billions de kilom?tres (9,46 x 1012 km)
L'?toile la plus proche de la Terre est Proxima Centauri, ? 4,2 ann?es-lumi?re
Les galaxies les plus ?loign?es se trouvent ? plus de 13 milliards d'ann?es lumi?re. L'?toile la plus ?loign?e est de 9 milliards d'ann?es lumi?re.
How to fix blue star inviter e6 erro
The E6 error code indicates communication failure between the inside and outside unit. First thing to try is turning off the power which you have already done. Next thing to check is the wiring connections between inside and outside unit.
