20 Most Recent
RCA TH1500 MP3 Player Questions & Answers
Need to remove songs from mp3 player
TO DO THIS YOU HAVE TO CONNECT THE MP3 PLAYER TO A COMPUTER IF ITS NOT THE SAME ONE THAT YOU USED TO PUT THE SONGS ON WITH IT'LL DELETE ALL YOUR MUSIC ON YOUR MP3 IF THIS HAPPENS THEN JUST RE-INSTALL THE MUSIC YOU WANT TO PLAY ON YOUR MP3
Freezing up....
Make sure the mp3 files that you are adding are definitely in Mp3 format, rather than AAC, CDA or WMA. If they are mp3, then check the sampling rate - try cutting the sampling rate in half through Windows Media Player. Also, if you obtained the songs through Limewire, delete all songs from the device, clear out the "Comments" line using the "Advanced Tag Editor" function in Windows Media Player, and then reload them.
-Tha Mp3 Doctor
Reformat Internal Media as FAT16
Depending on the requirements of the mp3 player, you may just have to right-click format in Explorer, or a computer guru friend to format it for you with a partitioning program if it needs a partition table.
Matsui 2gb mp3 player
Format your Mp3 device by the right click option and select format and now move new audio files and try to play the songs. it will work.
My RCA home theater system,
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
1/15/2024 9:01:27 AM •
RCA Audio...
Answered
on Jan 15, 2024
