20 Most Recent
Mustek MP72 7-Inch Portable DVD Player Questions & Answers
Portable DVD player. Why is there no video display?
Most of the time when the LCD screen has gone black it means that the ribbon cable is either loose or a capacitor or or a resister in the main board went bad . Try moving the screen around a little bit to see if the picture is going to show up on the screen on your portable DVD player . You can try returning the item or get it repaired
I have a portable DVD
This means that the battery is unable to hold a charge any longer. THe only option in this case is to replace the rechargeable battery for your Yukai 700. A battery has a charge life meaning you can only charge it for a set number of times. It seems that it has already exceeded that.
Dvd player is saying wrong
DVD is most likely locked to a certain region, and the disc you are trying to play is of a different region
Half way through a replay
left the unit fo 24 hours, reconnected it just as before and did a channel search (scan). Up came all available channels, recorder also appears to be fine. I am utterly mystified as to how a genuine fault condition one day (triple-checked for sanity) can fix itself. Fix double-checked to ensure AOK. Crazy.
