20 Most Recent
Sanyo Vpc-s1414 14 Mp Digital Camera Vpc S 1414 Purple - Cables Included Questions & Answers
Camera says batteries low, replace
Make sure you are using fresh batteries when you are replacing them. If you are using rechargeable batteries, let them charge until the indicator light on the base unit turns green. If the indicator light on the base unit flashes red, the batteries are no longer good.
Cheap batteries form dollar stores (Sunbeam, or store brand name) do not last long, and digital point and shoots eat up those types in a few uses. Best to use Duracell or Energizer batteries for Cameras. They dont have to be Lithium, or digi camera specific batteries. Those are expensive and unnecessary. Basic Duracell or Energizer will do.
Hit FORMAT and thought I was saving pics..but now
try to insert that sd card/ memory card to a laptop or memory reader of a desktop just to be sure if there something on it. if the screen says nothing other than no image then... its true you erase every thing on it...
Sanyo put date on pictures
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
I can't upload photos to my computer because the device is unrecognizable
Consider NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
Sanyo VPC-T1496 Battery issues
Talk to Kastar and tell them there battery messed up your camera. I am assuming the camera was working OK when you got it.
