20 Most Recent Dell NPS-110AB (NPS110AB) 110-Watt Power Supply Questions & Answers
Dell Optiplex G110 power supply unit replacement
Yes you can replace the old defective power supply with the new atx but the problem is the size. It the size it fit to your computer nothing to worry because power supply now is almost the same output only the wattages changes.
5/4/2009 10:46:37 AM • Dell NPS-110AB... • Answered on May 04, 2009
Dell power supply NPS-110AB 85-Watt Power Problem
its brown or gray which ever is there and the second one is black
6/6/2008 2:20:53 AM • Dell NPS-110AB... • Answered on Jun 06, 2008
Powersupply
first you switch on the supply by shorting (green and black )wire in output socket of smps.then check output voltages.If there is no voltage then check switching transistors or protection transistos that is placed on first hit sink.check primary bridge and capacitors for open.
5/24/2008 12:37:37 PM • Dell NPS-110AB... • Answered on May 24, 2008
2answers
Dell Latitude won't connect to internet. Windows XP.
It is too old, plus XP is a virus magnet and has been unsupported by Microsoft for nearly 15 years. Mainstream support for Windows XP ended on April 14, 2009. Windows 7 and 8 have passed you by, Windows 10 is current and Windows 11 awaits. https://www.google.com/search?q=Dell+Latitude+won%27t+connect+to+internet.+Windows+XP ..
4/25/2024 4:08:35 PM • Dell Computers &... • Answered 9 hours ago
2answers
I want to know about some adventures video games?
Check out Big Fish Games. It is a subscription service but they have all types of games including adventure and hidden object. You can also tryp Pogo since they have both a fee and subscription service. Last, but not least, you can try one of your local computer stores or the electronics section of "big box" stores like Target, Walmart, Kmart, etc.
4/19/2024 6:52:18 PM • Dell Computers &... • Answered on Apr 19, 2024
2answers
Where can I get a replacement adapter cord for my Dell 3052 - 20" all in one model reg model W158?
Amazon, or if you only want the main lead, Walmart.
AC/DC Adapter For Dell Inspiron 20 Model 3052 20- ...
Amazon.ca https://www.amazon.ca > Adapter-Inspiron-20-3052-... AC/DC Adapter For Dell Inspiron 20 Model 3052 20-3052 W15B W15B002 All-in-One Desktop PC Power Supply Cord Cable PS Battery Charger Mains PSU : Amazon.ca: ... $26.27 · ‎ In stock ..
1/11/2024 6:55:07 AM • Dell Computers &... • Answered on Jan 11, 2024
My dell laptop i5 does not recognize the external ac source
I would try another power supply and plug that in.
1/5/2024 9:01:17 PM • Dell Computers &... • Answered on Jan 05, 2024
Where is the reset button on the dell inspiron 3052 tag c99f22
Try replacing the BIOS battery for access to the computer.
10/23/2023 4:58:31 AM • Dell Computers &... • Answered on Oct 23, 2023
Are there any other ways to bypass the log on screen on a dell inspiron 3052 so i can factory reset it
Windows can be accessed renaming two files. computingterror.blogspot.com/2014/03/hack-windows-7-login After that being done you should run the Support Assist OS Recovery from DELL dell.com/support/kbdoc/en-us/000177401/restore-your-system-using-dell-supportassist-os-recovery Windows 10 can renew itself, without Windows Setup on a USB medium.
10/23/2023 4:55:37 AM • Dell Computers &... • Answered on Oct 23, 2023
Alpha Lansing ACS400; Dell Inspiron 3020 Windows 11. PC won't recognize speakers. No sound.
Go here [9 Ways] How to Open Windows 11 Device Manager Quickly? - MiniTool Remove all device under sound video and game controllers, and audio in and out.. Then reboot your computer.
10/4/2023 10:39:39 PM • Dell Computers &... • Answered on Oct 04, 2023
I've got a dell inspiron 20 model 3052 series how do you reset it to factory settings or reset the password thought it was a monitor any help would be very greatfull!
Unfortunately, resetting a Dell Inspiron 20 model 3052 series to factory settings requires you to use a recovery disk or USB drive, as the system does not include a built-in resetting option. To reset your password, you will need to use a password or recovery disk. You can create a password or recovery disk using the Dell Support website.
9/2/2023 11:52:56 AM • Dell Computers &... • Answered on Sep 02, 2023
Dell Precision M4600 will not go past POST, Stops at Preparing to enter setup
If your Dell Precision M4600 is getting stuck at the "Preparing to enter setup" stage during POST, you might want to try a few troubleshooting steps. 1. **Power Cycle:** Disconnect the laptop from the power source, remove the battery (if possible), and hold down the power button for about 15 seconds. Then, reconnect the battery and power source and try booting again. 2. **Reset BIOS:** You could try resetting the BIOS settings to their default values. To do this, look for a small button battery on the motherboard. Disconnect the laptop from power and remove the battery. Press and hold the power button for a few seconds to discharge any remaining power. Then, locate the battery, remove it for a minute or so, and put it back. This will reset the BIOS settings to default. 3. **Update BIOS:** If the issue persists, you might need to update the BIOS. Check the Dell support website for your laptop model and download the latest BIOS update. Follow the instructions to update the BIOS. 4. **Check Hardware:** If the issue is not resolved, it might be related to a hardware problem. Try removing and reseating components like RAM, hard drive, and any expansion cards. 5. **External Devices:** Disconnect all external devices (USB drives, external hard drives, printers, etc.) and try booting again. Sometimes, a faulty external device can cause boot issues. 6. **Diagnostic Lights:** Dell laptops often have diagnostic LED lights that provide information about hardware issues. Check the user manual for your laptop model to interpret these lights. If none of these steps resolve the issue, it might be worth seeking professional assistance or contacting Dell support for further guidance.
8/23/2023 8:49:51 AM • Dell Computers &... • Answered on Aug 23, 2023
Empowering technology windows xp
We recommend upgrading to another level of operating software, or perhaps windows 7 windows 8 is that they are available for more security and development update...We recommend upgrading to another level of operating software, or perhaps windows 7 windows 8 is that they are available for more security and development update ... windows 7 upgrade will soon be without ...
8/12/2023 6:02:40 PM • Dell Computers &... • Answered on Aug 12, 2023
Im trying to factory reset my dell inspiron 1100
Maybe this will help. https://www.dell.com/support/kbdoc/en-us/000192008/how-do-i-erase-data-from-my-hard-drive-or-mobile-device-before-trade-in
8/8/2023 8:57:40 PM • Dell Computers &... • Answered on Aug 08, 2023
Bios boot password on Dell Inspiron 7737?
This may help. https://www.dell.com/support/kbdoc/en-uk/000131024/how-to-clear-the-bios-password
8/4/2023 8:37:29 PM • Dell Computers &... • Answered on Aug 04, 2023
Computers & Internet Logo
6 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
  • Dell Computers & Internet
Most Popular Question
dell power supply nps 110ab 85 watt
  • Computers & Internet
