20 Most Recent
Dell P1110 21" CRT Monitor Questions & Answers
Bom dia. me chamo Giuliano,
try English?
you can see we are English only.
or go to google translate,
then translate it to English and post that?
You in Brazil?
screen to bright.
go to Dell.com and ask there, they designed it and built it and support it, always go to makers site first.
NO OS stated.
I have a wide screen Dell 21
change the resolution from the desktop properties(right click on desktop ..choose properties than settings ...in there you will find resolution ...setting ..change them one by one untill you get to one that fits...probably will be the last one in the right ..the largest if it is a wide screen on 21 inch ..
I am replacing the 10M resistor with a lower value
If you cannot find a 10M ohm resistor you can connect lower value resistors in series so it totals to 10M (ie two 5M resistor in series equals 10M). The only thing you need to be careful is to make sure the wattage is the same or higher than the original resistor.
Monitor went blank and started to make a low
Check the input selector and make sure issue occurs on both input 1 and input 2 video connections.
If it does, there are no user serviceable items inside the Monitor and you will need to have the monitor serviced if you want it fixed. Most likely failure is the flyback transformer.
NOTE: you can get a replacement 22 In LCD monitor for about $150, repair to the P1110 will likely cost more.
Having problem with display
Make sure you have the right cables from the other monitor/tv
To access dual monitor setup:
1. Right click on your desktop screen
2. Select Properties
3. Click the Settings Tab
4. Click No.2 Screen
5. Click extend my windows desktop onto this monitor
6. Click apply
7. Click ok
Hope this helps
I want to know about some adventures video games?
Check out Big Fish Games. It is a subscription service but they have all types of games including adventure and hidden object. You can also tryp Pogo since they have both a fee and subscription service. Last, but not least, you can try one of your local computer stores or the electronics section of "big box" stores like Target, Walmart, Kmart, etc.
