20 Most Recent
LG 500g Black tracfone CePhone Lg500g DoubMinutes Qwerty Mp3 Camera Questions & Answers
Can i track my tracfone?
All cell phones can be tracked at least as far as proximity of location(Cell phones need to know what towers are close by to connect to) but I think your talking more along the lines of GPS tracking which the LG 500G does not have. And I believe proximity location tracking is only available to emergency and police services.
How do i factory reset lg trac fone
go to ,
- settings
- then select OTHER SETTINGS
- then select INITIAL SETUP
- MASTER RESET
- enter 1234 as a password and it will be back to factory setting
Need screen help as soon as possible!!!!!
take it to a radio shack store or to a cell phone provider like sprint or att and have them reset your phone. It normally does not cost anything but ask first to be sure. good luck.
Tracfone Driver Download??
Yes you need USB driver for your cell phone;
Please visit LG website for the USB drivers
http://www.lg.com/us/support-mobile/lg-LG500G
I want to know if I can get wifi ?
Yes. To get to the internet you can it the button right next to the red power button on your phone or go to the menu and go till you see a globe with an airplane in front of it. However, it will us up .50 minutes. The longer you spent on the internet the more .50 minutes you are using up.
What is a PUK code
PUK Code PUK stands for Personal Unblocking Key. This is a unique eight-digit code specific to your SIM card. This is required when the PIN number to unlock your mobile phone is entered incorrectly 3 times. You are then given 10 attempts to enter your PUK code. If an incorrect PUK code is entered after the 10th attempt, you will block your SIM card permanently and will require a new SIM card from your mobile phone provider. PUK codes can be obtained through the following ways - The PUK code is in your SIM card documentation Starter Pack. If you do not have this then - Please contact your phone service provider. Your cell phone service provider can give you the PUK code once you give them your account details and they have confirmed your identity. For details to obtain the PUK code for the SIM card, please click on this link and follow my instructions.
http://www.fixya.com/support/r5705889-puk_code
Lg fb163-how to add bluetoth function
To add Bluetooth functionality to your LG FB163, you can use a Bluetooth adapter that is compatible with the device. Ensure that the adapter you choose is compatible with the FB163 model. Once you have the adapter, follow the instructions provided with it to connect it to your FB163 system.
To connect your Android phone to the FB163, you'll need a compatible cable. Typically, you would use an auxiliary (AUX) cable with a 3.5mm jack on both ends. Plug one end into the headphone jack of your Android phone and the other end into the AUX input port on the FB163 system. Then, select the AUX input mode on the FB163 to hear the audio from your phone through system.
How can I hatd factory hard reset my LG 265 if I don't have my pin # nomore or forgot it .
- Turn the phone off.
- Press and hold the Power/Lock key (on the right side of the phone) and the Down Volume key (on the left side of the phone) at the same time.
- When the Factory data reset screen appears, release both of the keys.
- Use the Volume keys to highlight Factory data reset, then press the Power/Lock key to confirm.
- Use the Volume keys to highlight Yes, then press the Power/Lock key to confirm one more time.
- Your phone will perform a factory reset.
