20 Most Recent
Gem Sound TR-150 Speaker Questions & Answers
If all speakers except some
Did you actually mean "all speakers... AREN'T working" except some tweeters? Crossovers don't protect the woofers. If crossover die all speakers they protect go silent due to loss of signal. Excess volume or distortion kills speakers and not always linearly.
If you said it wrong and some tweeters work, I'd suspect the latter above...
You (or we) could guess or you could take out one tweeter at a time and swap it with a (presumed) working one or just emasure it for dead short or open with an ohmmeter. If the tweeters check out and work elsewhere the problem would likely be within the cabinet.
I have a gem sound 1000 watt amp with no sound
Fuses blow when there's an overload. This is generally caused by a semiconductor acting as if was a piece of wire. You should look to the devices located on the big heat sink. If they are transistors a multimeter will show it quick. For on the ohms scale test leads across the terminals of each faulty transistor will be just like you had touched the two leads together!
