20 Most Recent
Sansui TVM1916 19" TV Questions & Answers
Need code for sansui TV SAN5452
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "
brand name" to your device; to which you want set-up codes; in the "
Search box at the top right of the display window" to get gathered related posts
Remote does not work for TV
I assume you had new batteries in the original remote and that the Universal remote was programmed correctly for your TV.
Are there any lights on the old remote that flash when you press a button? If so, does it light?
If the TV doesn't respond to a remote, and the remote is verified to be in working order, then the infrared sensor in the TV is defective amd needs replaced.
Good Luck,
- Jim
Tv stuck on lock
Hi
Did you mean child lock? if childlock you need a remote control to open this tv..
Thanks!
Remote can not work
Check the battery, If not there could be some dirt on the IR LED or did you drop the remote?
My sansui t.v wont turn on
1= you have problem with the main switch for open or faulty, test with VOM2=check the power supply: a)filter b= coil c= trafo d=diode e=rectifier f= fuse or c.breaker repair or replace3= HV rectifier for output horizontal +125 vdc +Flyback test4= vertical output +80Vdc 5=12vdc for color6= other circuite 12vdc.see the block diagramGod bless you
I bought a small sansui tv from walmart, but
I most certainly hope that after all this time, you were able to program your remote! But if you have any questions, haven't gotten it working, or have another tv and remote that you would like to program, I am here to help! The link below is a link to instructions for a power scan. The scan scans all of the codes on the tv until it finds the right one for the remote. It sounds tedious, but it is a quick and simple way to get that remote programmed to the tv. This scan works for every DISH remote, and you can use it on any tv, so if you have a tv in the future that you want to program with the DISH, this will help! It's a very handy thing to know!!!!
http://www.dishnetwork.com/SupportSection/power-scan-instructions
Becki
Barned
DISH Network Customer Service
User manual
Call their customer service number 800 289 0980.
New Sansui 27" and remote does not work
On later model Sansui tv's, you can bring up the menu by pushing both volume buttons on the front of the set at the same time. After the menu is on the screen, you can navigate using the channel and volume buttons.
Sansui tmv1916 tv no pic
have a sansui tv with a date of sept 2002 i bought the tv because it was on sale and have since lost the reciepts. anyways , no i need the tv and when powered up there is no picture but the sound comes on fine. i turnd it upside down and beat it and shook it and the pic came on for a min only to turn back off in 5-6 minutes. help. oh and i dont have electrical or circuit knowledge but willing to change a bulb or fuse.
as you say that sound is ok and picture also comes some time so please check loose contact in luminance section of chroma ic .
weak signal may cause rolling and intermittant picture problem for that checkloose near antena socket
thanks
