20 Most Recent
E-Mu 0404 Bundle Sound Card Questions & Answers
Hello sirs,
Win 7 32bit emu
click start control panel administrive tools ,computer management ,device manager scroll down image devices you could see a yellow question mark? right click to reinstall drivers or update driver open skype go to tools from the drop down list select options scroll to audio settings you can make a free test call before you try to make a call make sure the microphone is using the same as your computers audio you can make a free test call if you cant get the microphone to work you can select learn about setting up your audio equipment also click start control panel sounds and audio devices audio and also voice it's the same make sure that you have the right default microphone selected you should be able scroll to video settings to make sure you have the right settings Open skype go to tools options scroll to audio settings or video settings on the right you will see webcam setting you can change the settings from there click apply after changing any settings also you can see the webcam there you can even take a snapsot also make sure your settings are correct for a video call also click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick also select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
I have windows 7 64,
Windows 7 does not run everything especially older softweare/hardware. That is why there is an upgrade advisor available to test the compatability.
It is an integral part of the instal disc and available for download before you try to install Win7
http://windows.microsoft.com/upgradeadvisor
I have just reinstalled Windows XP Professional
Please try to check if you have met the minimum requirements for Windows 7, check your memory if its enough for windows 7 and also your hard disk. And after installing back to XP you still encounter this problems try checking your memory again, detach it from the board and try cleaning it then insert back again.
0404 installed but cubase vst 5.1 will not load
vb-1 is a cubase virtual instrument this is where cubase was stalling, When i uninstalled cubase i went into the vst plugin folder and saw the folder vb-1 [virtual bass] I read the text file within and it told me to copy the dll files within into the active vst plugin folder. when i re installed cubase all was well. I have been using cubase for years and did not have this problem until i installed the e-mu 0404 pci card, or the audigy card
Open helpline
Well i know that the pci-e is build with only the 1 slot as power supply , instead of using the 12volt connector, which leaves it with very few power....
Uninstall reinstall clean install
Just install. the driver again or set your pc a couple of days back.
Nice card for the money, only why are you using the solo still...
How to Install YouTube DL.py to Download YouTube Videos to my PC?
Actually, you just need the help of a YouTube Downloader. If you still need help, why not try this YouTube/Video Downloader?
Leawo YouTube Downloader acts far more than a single online video downloader to download YouTube videos and other online videos from various video sharing sites like Facebook, Dailymotion, AOL, iFilm, Myspace, Dailymotion, etc. Besides the ability to download online flash videos, this FLV downloader could also acts as video download accelerator to speed up online video downloading, video accelerator to speed up video buffering for smooth playback, video player to play back videos, and IE browser to browse online videos for free downloading. It could extract audios out of online videos, like converting YouTube video to MP3.
Hope it can be another choice for you or other users. :)
Watch online videos offline freely with Leawo YouTube Downloader
What is digital marketing?
Digital marketing, or “online marketing,” is a form of advertising that uses the internet and digital technologies to connect with customers. Digital marketing seeks to accomplish the same thing as traditional marketing except by leveraging computers, smartphones, and other digital devices rather than traditional media, such as print, radio, or television.
