20 Most Recent
Maclaren Twin Techno Storm Umbrella Stroller Questions & Answers
Maclaren Twin Techno bent frame
The Maclaren umbrella strollers are made to be as light as possible, often using a thin-wall aluminium tubing which is very vulnerable to bending where it is drilled to attach things to - the points where rivets and suchlike are placed are downright weak and unless great care is used and you have a lot of luck attempting to straighten a bend results in fracturing the tube.
In the case of a fracture all is not lost and repairs can be made. After some gentle reshaping the break can either have a splint or sleeve fitted or because it is a tube an insert could be used to bridge the break, or both methods for a really strong repair.
Such a repair that is well executed and a good adhesive used can be stronger than before. Professionals that repair baby buggies and carriages are few and far between and expensive but the task is within the scope of any good handyman that collects odd bits of tubing "in case they come in handy one day".
Almost everyone knows someone like that or should know them...
Instructions for Maclaren Twin Traveller
i find the clips on the side that keep it closed keep sticking when im opening the buggy so i unclip one side and pull it apart then do the other side once the wheels start falling press down on the metal frame with your foot - do this on both sides and it should be open :)
I am looking for a
- If you have any comments please feel fre to leave them here.
- Hope this helps and thank you for using FixYa.
Regards,
Tony
How to fold twin techno
Hi
Check this out - but you might want to skip to the 5 minute spot!!
www.youtube.com/watch?v=SfnQowDiAmU
Basically you need to lift up the middle section of the bars at the back of each seat and then push forward on the handles.
Hope this is helpful.
I have a broken snap (snap that connects stroller
You don't mention which side failed? It's usually the female one in the cover. Try your local haberdashery / local sewing supply shop. take the cover in and they can try to match it. You may need to sew a small piece of reinforcement material into the cover.
How to alter the saftey harness
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Can I remove the material on the stroller to wash
should have scews holding material in place,remove these and material will come of,if its not screws then my advice is to you babywipes or us a scubber ,with water and washing up liquid,sparingly,but always put screws back as you take them out
Hood for my maclaren volo
you can order one for $35 from here:
http://www.maclarenbaby.com/us/content/view/164/88888914/lang,en/
Twin techno stroller problem
Contact Us
Maclaren USA INC
4 Testa Place
South Norwalk
CT 06854
USA
[email protected]
Can I bring my buggy to Maclaren for repair?
Vist our authorised service agents page to find the closest service
agent or contact customer service contact customer service at:
GLOBAL: +44 (1) 327 841 320
UK: +44 (1) 327 841 320
US: 1-877-442-4622
Maclaren volvo wheels
there is a shop on Ebay which you can but repalcement wheels, thry cost £30 for 4. Sorry i cant remeber the name of it but if you type in replacement wheels it'll come up.
I hope this helps
