20 Most Recent
Altec Lansing (AHS-322) Headset Questions & Answers
My mic is broken
What i've done in similar situations is basically trail and error. You've got two spots for one wire, try them both out.
Some companies will use a generic piece for all their similar products. Maybe one of Altec's other headsets uses that 5th spot for something. Just try them both out and see what happens. Just dont solder them right away, stick them on with some electrical tape or something to save yourself some time. Then when you're sure you can solder away.
EX-02s mic not working
I have giotech ex-02s and when I hook it up to my ps3 it won't charge how do I fix this?
Is there something special I need to do to get the
Shouldn't need drivers for this. Open System Preferences, which can be found in the Utilities folder, if it is not already on your Dock. It looks like a light switch with an apple logo on it. From there select Sound, under the hardware section. Click output, select the headphones, select Click input, again select the headphone/mic set. If it is not on the list, then so sorry, i was wrong, you need drivers, which you should be able to get from the altec lansing site.
If this is set and you still cant here, please let me know what system he is using. Is it the in game one from WoW? Ventrilo? If vent he will need the server data etc. from his guild or friend he is trying to speak with. If it is the in game one, just tell him to follow the in game instructions, they are fairly straight forward.
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
on Apr 19, 2024
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please.
Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity.
https://www.google.com/search?q=KPG-790
2/15/2024 3:06:45 AM •
Radio...
Answered
on Feb 15, 2024
