This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
You need a new thermostat control for the oven fan. That is what determines when the temperature of the oven is low enough that the fan is no longer needed. Based on your description, the thermostat has failed in the "closed" position which means that it is always supplying power to the fan.
Hellostarsevern!!Did you get your cooker fixed, what was the problem? I have a Zanussi ZCE7550, but apart from that I'm in exactly the same predicament as you in the post you made on Sep 18, 2010... Can anyone help with a suggestion please???
Here is a free video to help you with your cooker fan motor problems
and how to fix them
For all your free videos on appliance repairs remember to
mark us down and leave feedback please
For all your parts visit our site http://www.apart4u.co.uk
It is probably a worn fan bearing, or loose or broken fan blade.
You could try spraying the bearings with WD40,
which may quiten it down, but normally the only solution is to replace the fan motor complete.
[Please rate my solution.
Thankyou.
If it is a fan assisted oven, and the fan is working, and it is an electrically heated oven, then you need to replace the oven element, this is located at the rear of the oven, behind a removeable cover.
Hope this helps.
Error code 367 on a Zanussi cooker typically indicates an issue with the temperature sensor or thermostat. When this error occurs, it means that the temperature sensor is detecting an abnormal or out-of-range temperature. Here are some possible causes and steps you can take to troubleshoot the issue:
Power cycle the cooker: Turn off the cooker and unplug it from the power source. Wait for a few minutes, then plug it back in and turn it on. Sometimes, a simple power cycle can resolve temporary glitches or errors.
Check the temperature sensor: The temperature sensor is responsible for detecting the oven's temperature and sending signals to the control board. It's possible that the sensor has become faulty or disconnected. Inspect the sensor for any visible damage or loose connections. If necessary, consult the cooker's user manual for instructions on how to access and check the sensor.
Inspect the thermostat: The thermostat regulates the oven's temperature. If the thermostat is malfunctioning, it could be causing the error code 367. Look for any signs of damage or wear on the thermostat. If you suspect a faulty thermostat, it may require professional repair or replacement.
Contact customer support: If the above steps do not resolve the issue, it's recommended to contact Zanussi's customer support or a qualified technician for further assistance. They will have the expertise to diagnose the specific problem with your cooker and provide guidance on the necessary repairs or part replacements.
It's important to consult the cooker's user manual or documentation for model-specific troubleshooting steps or error code interpretations. The manual may provide additional information or suggestions for resolving error code 367 on your particular Zanussi cooker.
If you have replaced the grill element and it still doesn't work, there are a few other things you can check.
First, make sure that the grill is actually turned on and that the grill control knob is set to the correct temperature.
Next, check the grill's thermostat, which is typically located near the grill element. Use a multimeter to check the continuity of the thermostat, as a faulty thermostat can prevent the grill from heating up.
If the thermostat is functioning properly, you may need to check the grill's selector switch, which determines whether the grill or oven is used. A faulty switch can prevent the grill from working.
Finally, if none of these solutions work, there may be a wiring issue within the grill or in the main control board of the cooker. In this case, it may be best to seek the assistance of a professional technician to diagnose and repair the issue.
Both gas and electric ovens will cycle on and off throughout the cooking cycle to maintain the set temperature. When the oven temperature has dropped below the set temperature, the oven cycles on again to provide heat and will cycle off again once the temperature is higher than the set temperature.
I have/had the same problem with the top screw not staying in, I have left it like that for quite a while as I didn't want to pay someone for what I thought would be an easy fix, such as finding a replacement screw or discovering a new way to put it back together that fixes it.
I couldn't do either of those and on a close inspection, the 'screw' that goes in the top looks like it is as big as it can be otherwise you would struggle to put it in the gap between the two ovens, so even though I couldn't find a replacement, that didn't seem to be the solution anyway.
So, now the waffle is out of the way, I decided to take a pair of pliers to it and bent the metal slightly up and bobs your uncle it solved the problem. I made sure to bend it only as much as I need to so that the door can still be taken off and it worked.
Go to Zanussi . com select UK then manuals you will need more information a serial number and then download it, there should be an answer in there okay.
Regards
John
Oct. 14, 2019 - Applies to: integrated oven; freestanding cooker. Resolution: 1. Deactivate the safety lock. Refer to the full description in the user manual, as the ...
