20 Most Recent
D-Link DSL-2640R Wireless G ADSL2 Modem Router Questions & Answers
192 168 1 1 admin password
Hi Dear,
NOrmally Your Username and Passwor is
User name: admin
Passwort: admin
But if it changed DO THE following
• Ensure the router is powered on.
• Press and hold the reset button on the back of the device for approximately 6-8 seconds.
• The process would take about 30 seconds to complete.
Wps button on the router
Hi log into your router open Internet Explorer then enter the default Ip address
Default IP: 192.168.1.1
Default Username: admin
Default Password: admin
once logged in you'll need to go to wifi settings you'll find what you need there. I don't have this router but this is where you'll set all wifi etc. hope this has helped
Internet signal keeps dropping
There's a lot of possiblities here.If you have a DSL/dialtone lineshare,listen for noise on the line(humming,crackling static,dropped calls).If you have a dry loop(DSL only),connect a phone in place of the modem and see if it has an "intercept" message(like "you have tried to call a number out of your service area" or something like that).If it does,you can use a phone to check the line when the DSL drops(don'touforget to put an inline filter on it).If the DSL light doesn't go out when the Internet light does,it is NOT a problem with the physical line.This would be an issue with the modem or the equipment at the serving end.( I am a DSL tech,and spend lots of wasted time diagnosing and trying to fix problems that are beyond my reach(central office server issue) or that I didn't need a dispatch for(it is cheaper to send a new modem than to send a tech).
9815813107 tell me name and adrress
You can find the details of the operator and the state they belong to .the operators wont reveal the address and name of any mobile numbers only higher officials can only get those information.
In order to trace the operator name and state you can try this link
http://www.indiatrace.com/trace-mobile-number-location/trace-mobile-number.php
I hope this will help you if it does do rate the answer
Thank you
regards
lalith
