20 Most Recent MSI MS-6380E (MS-6380E-010) Motherboard Questions & Answers
Mother board can not see any device just bios
are all the cables plugged in right check all ribbons and power cables one by one make sure the red line is on the right way and the same as the power lines.
1/23/2014 7:46:54 AM • MSI MS-6380E... • Answered on Jan 23, 2014
Loose wires
1/12/2014 12:07:06 AM • MSI MS-6380E... • Answered on Jan 12, 2014
7028 driver sonido
drivers at msi web site download support ok
11/11/2013 6:32:36 AM • MSI MS-6380E... • Answered on Nov 11, 2013
2answers
I NEED MSI KT3 Ultra CE Motherboard MANUAL OF
the manual is available for download here. http://www.msi.com/index.php?func=searchresult&keywords=MS-6380E&table=download
make sure you have adobe free reader installed so you can view it..
Regards..
12/6/2012 1:25:06 PM • MSI MS-6380E... • Answered on Dec 06, 2012
Over charged
It's Dead.
6/28/2012 9:00:30 AM • MSI MS-6380E... • Answered on Jun 28, 2012
2answers
I just bought a msi
If you are looking for the motherboard device drivers then -
You can download the device drivers from MSI WEB supportsite, select your model motherboard to download :- http://www.msi.com/index.php?func=downloadindex
9/9/2011 6:19:18 AM • MSI MS-6380E... • Answered on Sep 09, 2011
San makakakita ng libreng sound drive download
You can download the drivers from MSI WEB support site,select your model motherboard to download :- http://www.msi.com/index.php?func=downloadindex
4/8/2011 6:51:44 AM • MSI MS-6380E... • Answered on Apr 08, 2011
After a short while, I
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off. the grrr is the sound its not getting enough power test your PSU power supply unit or replace it if the fan is not working the PSU is faulty One bad/faulty lead can cause a computer with lots of problems replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ? hope this helps
12/27/2010 8:50:02 PM • MSI MS-6380E... • Answered on Dec 27, 2010
HELLOO SIR I HAVE INSTALLED THE
click my computer then control panel click performance and maintenance click system then click hardware click device manager then click sound video and game controller if there no question mark your software is installed so go back to control panel click sound,speech and audio device then click where you want to adjust
8/19/2010 3:55:56 PM • MSI MS-6380E... • Answered on Aug 19, 2010
No sound
Please Install the Audio Driver From *********** Board Cd Or Call Your Vendor!!
Vikas Agrawal
Vikas Tricks Online!!
5/28/2010 8:40:17 AM • MSI MS-6380E... • Answered on May 28, 2010
I have a problem in my audio what site recommend
It's best to get drivers directly from the device manufacturer's site. This way you'll get the latest version.
If your computer is a name brand you can usually find the drivers by following the "support" or "downloads" link on their site. (I say "usually" because some companies make it difficult.) This should be your first place to check as some companies use special versions of drivers to support custom hardware. Generic driver versions may not work or support all features.
For homebuilt or custom systems, you can get drivers from the motherboard manufacturer's site (if the sound is built into the motherboard) or sound card manufacturer's site (if using a separate sound card).
Finally, there are many sites online where you can download drivers if the first two methods don't work. Just be aware that drivers from these sites may not work, or contain viruses. Be sure to have up-to-date antivirus software running in your computer.
2/2/2010 12:00:10 PM • MSI MS-6380E... • Answered on Feb 02, 2010
Need to know where front connectors for firewire usb go
ok..here is the link from the official MSI site ..download the pdg manual..and good luck instaling...
bye;)
2/6/2008 11:45:44 PM • MSI MS-6380E... • Answered on Feb 06, 2008
2answers
How do i download MSI N082 graphics driver
To get the MSI N082 graphics driver: 1. Find your graphics card model. Note down the model number. 2. Go to MSI's website. 3. Look for the support or downloads tab and click on it. 4. Use the search or menu options to find drivers for your specific graphics card model. 5. Download the driver package. 6. Run the installer file once the download is complete.
3/26/2024 10:36:50 PM • MSI Computers &... • Answered on Mar 26, 2024
Screen does not fit after adjusting the screen resolution msi N082 i tried updating the VGA driver online but it keeps telling me that driver is up to date
If adjusting the screen resolution didn't resolve the issue and you've already updated the VGA driver, try manually adjusting the display settings through your computer's control panel or display settings menu. Look for options like overscan or scaling to ensure the screen fits properly. If the issue persists, it could be a hardware problem or compatibility issue with your monitor. Consider reaching out to MSI support for further assistance.
3/26/2024 12:50:33 PM • MSI Computers &... • Answered on Mar 26, 2024
How do i connect my fire stick thru bluetooth on my MSI windows 11 laptop??
To connect your Amazon Fire Stick to your MSI Windows 11 laptop via Bluetooth, you will need to follow these steps:
  1. On your Fire Stick, go to Settings > Display & Sounds > Enable Bluetooth.
  2. On your MSI Windows 11 laptop, go to the Windows Settings > Devices > Bluetooth & other devices.
  3. Turn on Bluetooth on your laptop and make sure that it is in pairing mode.
  4. On your Fire Stick, select your laptop from the list of available devices.
  5. On your laptop, click "Pair" when prompted to complete the pairing process.
  6. Once connected, you should be able to stream content from your Fire Stick to your laptop.
1/20/2023 11:59:27 PM • MSI Computers &... • Answered on Jan 20, 2023
Wanting to connect an older AV received to my Win 10 PC via optical input. Should I use MB or Graphics output?
You should use the audio output on your computer that is labeled as "optical" or "S/PDIF" (Sony/Philips Digital Interface Format) to connect to the optical input on your AV receiver. This will typically be labeled as the "digital audio out" or "digital output" on your computer. The "graphics output" is used for video, not audio.
1/12/2023 2:39:40 PM • MSI Computers &... • Answered on Jan 12, 2023
How can i enter the bios on my pc.
Proper training and equipment are needed to modify the (Basic Input Output System ) BIOS on a PC. You could turn your PC into a paper weight. The game has been criticized for its anti-cheat software, Vanguard, as it was revealed to run on akerneldriver, which allows access to the computer system.[56]OSNewsexpressed concern that Riot Games and its owner, Chinese technology conglomerateTencent, could spy on players and that the kernel driver could be potentially exploited by third parties.[56]However, Riot Games stated that the driver does not send any information back to them, and launched abug bounty programto offer rewards for reports that demonstrate vulnerabilities with the software.[57][58]The bounty will reward white hat hackers between $25,000 to $100,000 for reports on its vulnerabilities, with the pay being based off the severity of the exploit.[59]Gameplay bugs do not qualify for this bounty.[59] Valorantwill not run onWindows 11if the system does not have aTrusted Platform Module(TPM) 2.0 compliantcryptoprocessorandUEFI secure bootenabled, as mandated by Microsoft's minimum system requirements for the operating system.[60]
11/20/2022 7:19:17 PM • MSI Computers &... • Answered on Nov 20, 2022
Replacing an msi laptop screen
no PC told at all MSI is maker only but yes they all unplug on laptops(is it) they are held on by tricky ways and if forced you break mobo or display there are the easy ones push on pull off the the wedge locked, , unlocked first. and last the hinge lock FFC cable ends learn not to force them, look first for locks, 2/3rs of them are locked.
8/22/2022 8:33:42 PM • MSI Computers &... • Answered on Aug 22, 2022
MSI MS-6380E (MS-6380E-010) Motherboard Logo
22 questions posted
Top MSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • MSI Computers & Internet
Most Popular Question
loose wires
  • Computers & Internet
