20 Most Recent Vision Fitness 2011 Vision T9800 Hrt Treadmill Questions & Answers
My vision treadmill T9800 HRT when start shows
please see the 2 alternatives for error 7. God bless you E7- 1) Alternative Elevation Motor 1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection 2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate 3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation 4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor 2)Alternative: Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet c) Cause: Line Cord Damaged Solution: Replace Line Cord d)Cause: Fuse Solution: Check Fuse on MCB
9/20/2013 11:51:35 AM • Vision Fitness... • Answered on Sep 20, 2013
My vision treadmill T9800HRT when start shows
please see the 2 alternatives for error 7.God bless you E7- 1) Alternative Elevation Motor 1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection 2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate 3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation 4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor 2)Alternative: Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet c) Cause: Line Cord Damaged Solution: Replace Line Cord d)Cause: Fuse Solution: Check Fuse on MCB
9/20/2013 11:51:10 AM • Vision Fitness... • Answered on Sep 20, 2013
0answers
Vision Fitness E1500 Upright Exercise Bike. It will not turn on?
Question edited for clarity and toss in some CAPS. It is sold as an entry level fitness bike, but try the troubleshooting or contact them direct.
Troubleshooting ' Vision Fitness - United States
Vision Fitness https://www.visionfitness.com > eng > support > troubl... Make sure the treadmill switch is turned on. Solution: Check the power cable for crimping. Unplug the treadmill from the wall outlet, then wait 60 seconds to ... ..
10/8/2023 1:10:56 AM • Vision Fitness... • Answered on Oct 08, 2023
What's wrong with my Vision T9450HRT treadmill?
I have this same issue, have you found a solution?
11/19/2022 8:37:05 PM • Vision Fitness... • Answered on Nov 19, 2022
My exercise bike makes a grinding noise
Your diagnosis is good. The wheel should be more centred. You are not alone. Contact the maker, the details are in the link. https://www.google.com/search?q=vision+fitness+u40+grinding+noise ..
12/28/2021 2:45:55 AM • Vision Fitness... • Answered on Dec 28, 2021
2answers
I can run the unit for a few seconds before the 'E1' error appears...
1)probably a faulty speed sensor 2) the speed sensor is not plugged in properly.3) possibly a faulty motor test for 115 vca without load 4) control board or lower board for measure 115 vca and +5vca 5) Run the calibration sofware for easy diagnotic see the diagram attached.6) Test the transformer for primARY VOLtage and secondary voltage. see the TIP. The error codes will differ between makes and models but could be e1.http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnesshttp://www.fixya.com/support/r10786838-test_procedure_dc_motor12_26_2011_5_05_23_pm.jpg12_26_2011_5_06_14_pm.gifSincerely. Happy New Year . G-d bless youernesto cuadramanagua,nicaragua c.a.
3/4/2019 7:07:06 PM • Vision Fitness... • Answered on Mar 04, 2019
I have a T9450 VISION FITNESS TREADMILL THAT WHILE WALKING ON IT, IT SHUTOFF ABRUPTLY,EVERYTHING LIGHTS UP BUT BELT WON'T MOVE.
First thing to do with these folding vision fitness treadmills is REPLACE THE MAINS SUPPLY CABLE They were supplied with very poor quality cable that cause issues like juddering stopping and speed fluctuations.
3/4/2019 7:02:36 PM • Vision Fitness... • Answered on Mar 04, 2019
Vision Fitness R1500 recumbent bike was pedalled in reverse (while turned off) The bike now when turned on has no resistance. No manual to determine how to troubleshoot. Any help.
My guess is the drive belt has come off. Open the plastics up slightly and look in with a torch.
12/24/2018 3:24:42 AM • Vision Fitness... • Answered on Dec 24, 2018
Vision Fitness 2011 Vision T9800 Hrt Treadmill Logo
9 questions posted
Top Vision Fitness Exercise & Fitness Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
Sportsmith LLC
Sportsmith LLC
Are you a Vision Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Vision Fitness Exercise & Fitness
Most Popular Question
vision treadmill t9800hrt when start
  • Exercise & Fitness
