20 Most Recent
Sony Wega KDF E50A10 TV Questions & Answers
Standby/power light flashes 3 times.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Picture does not fit
Adjust the picture settings in the main menu until the picture fits. Not much information to go on, sorry.
Sony Wega T.V. won't stay on.
Over Voltage Protection 03. Three blinks of standby light denotes this. The fault is with its main power regulator section circuit. If you wish to get more details about these blinking codes, check this link. If you are not familiar with electronics, do not attempt to
repair. Whether you suffer fatal electrical shock!
Instead, contact the nearest service center.
Screen turns off and on, stand by light flashes
How many times do the standby light blinks at once time of switch ON. Count these numbers carefully for at least 3 times power ONs. These are fault indications. From these counts, you can detect the location of the faulty stage inside the TV circuit.
Check this link for more details about blinking codes to Sony TVs. All details are there.
Vertical lines
Check all the flat cable connections from and to, to the T'Con board for any loose seating. Re-seat them. To know more about this type of fault, check
this link. It has details with illustrations about these kind of faults to Sony TVs.
We have a sony wega KDF e50a10
Over Voltage Protection 03. This is the fault. Visit the site named 'Electro-help' for
more details. Click this link. View it in
"Timeslide" or "Flipcard" option, which can be selected
from the drop down box menu by the [Sidebar] tag, at the top left corner
of the display window. It will make
search easy. There are more than 1200 posts to different brand TVs now. Pull up
older posts there.Blinking codes to Sony TVs are described in detail.
I NEED CODES FOR MY NEWSTAR NTR-B28Z FOR MY SONY TV
ChatGPT 3.5
User
I need code for newstar ntr b28z for my Sony tv
ChatGPT
Unfortunately, I can't provide specific code for your Sony TV remote without knowing the exact model number. However, you can usually find the code in the user manual of your Sony TV or by contacting Sony customer support. Alternatively, you can try using the auto-search feature on your newstar ntr b28z remote to find the correct code for your Sony TV.
User
ChatGPT
To find the code for your Sony TV using the Newstar NTR B28Z remote, you can try these general steps:
Turn on your Sony TV.
Press and hold the "TV" button on your Newstar remote until it blinks twice.
Enter the code for Sony TVs. Some common Sony TV codes are: 0000, 0011, 0080, 0111, 1234. If none of these work, you can proceed to the next step.
Press the "Power" button on the Newstar remote. If the TV turns off, the code is correct. If not, try a different code.
Once you've found the correct code, press the "TV" button again to lock it in.
If none of the provided codes work, you might need to consult the manual of your Newstar remote or contact their customer support for assistance.
