20 Most Recent
Westinghouse Electric LD4655VX TV Questions & Answers
Hdmi dont work on my 46in westinghouse
The input selection on your television must match the input you have the cable in. If you are plugged into HDMI 1 then your input selection on your television must be on input 1 as well. That will be on your remote control with a button labeled input or source.
LD-4655VX
Set has a conventional fuse--follow the power cord inside as it goes directly to the fuse--if power light comes on at all even for a moment the fuse is good and you may have a power supply board bad.also look for puffed up caps on the power board that look like these=
My westinghouse tv does not turn on
Someone needs to look inside for blown fuses, or even bad caps in the power supply, care needs to be taken if you have never done this before.
