20 Most Recent
Bushnell Advanced 78-4030 Tripod Questions & Answers
783001 tripod manual
Most tripods do not come with manuals. Never have, so I doubt you'll find one. Try taking it to a camera repair shop and they can tell you how to use it or if it needs some parts.
11/13/2014 4:10:37 PM •
Bushnell...
Answered
on Nov 13, 2014
Hi. I inherited a Bushnell Sky Chief 1 (78-5500 Banner Astro 280).
you have 2 choices re tripods.
1. a normal pan and tilt photographic tripod, cheap and easy to use.
2. a Equatorial tripod, much more expensive and more difficult to use but can be setup to track the movement of the earths spin.
I use a photo tripod as its easy to use and quick setup.
11/3/2018 6:13:54 AM •
Bushnell...
Answered
on Nov 03, 2018
Lost screw that attaches scope to bushnell window
If the screw is standard, it is probably what's called a 1/4 x 20 screw. They only cost a few cents at your local hardware store (Lowe's, Home Depot, Ace, etc.). If it is proprietary, you may need to take the scope and the tripod to the hardware store and try a couple of sizes to see if anything fits.
Of course, you could also try bushnell's website to see if you can order parts.
2/7/2011 5:28:29 PM •
Bushnell...
Answered
on Feb 07, 2011
Setting rifle mode
HI,
Can you please give me the model no. so that i can provide you with a user manual if it is available.
8/15/2008 5:46:40 PM •
Bushnell...
Answered
on Aug 15, 2008
Film won't load on Vectis 300 MinoIta
The clue is in your descrition; Old.
If the mechanism has jammed, due to age or lack of use that causes tarnisg=hing on the contacts, the motor/mechanism will not load.
I would get it serviced at an aurgorised Minolta repair shop.
Contact Minolta for a list of authorised repairers.
3/22/2024 7:04:40 AM •
Photography
Answered
on Mar 22, 2024
I tried to use a 16GB PNYcard in my picture fram and it would not work. It said "No Card" on the screen. What's the answer?
If your picture frame is not recognizing the 16GB PNY card and displaying a "No Card" message, there could be several reasons for this issue:
- Compatibility: Some picture frames may have limitations on the size or type of memory card they can accept. Ensure that the picture frame is compatible with SDHC or SDXC cards, as these are the types commonly used for higher-capacity cards like 16GB.
- File System: Check if the memory card is formatted in a compatible file system such as FAT32 or exFAT. Some picture frames may not recognize cards formatted in other file systems. You may need to format the card using a compatible file system on your computer before using it in the picture frame.
- Card Reader Slot: Ensure that the memory card is inserted correctly into the card reader slot of the picture frame. Sometimes, improper insertion can prevent the device from detecting the card.
- Card Compatibility: While SDHC and SDXC cards are generally backward-compatible with devices that support SD cards, some older picture frames may have limited compatibility with higher-capacity SD cards. Try using a lower-capacity SD card (e.g., 2GB or 4GB) to see if the picture frame recognizes it.
- Faulty Card or Picture Frame: If none of the above solutions work, there may be an issue with either the memory card or the picture frame itself. Try using the memory card in a different device to check if it's functioning correctly. Similarly, try using a different memory card in the picture frame to see if it's able to recognize it. If the problem persists, there may be a hardware issue with either the card or the picture frame, and you may need to contact the manufacturer for assistance or consider replacing the faulty component.
By following these troubleshooting steps, you should be able to determine the cause of the issue and resolve it accordingly.
3/16/2024 9:30:07 AM •
Photography
Answered
on Mar 16, 2024
Need OptiPix Pro software
I own the OptiPix DPF and here is a pic of the owners manual with directions for the OptPixsetup file.
11/25/2023 1:11:02 AM •
Photography
Answered
on Nov 25, 2023
