20 Most Recent
LG 37LH3000 37" HDTV LCD TV Questions & Answers
37lh3000
What is the problem with colours? Provide more details; please. If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Find my IP address
To have an IP address, your TV must be connected to a home network or the internet...Is your TV a internet-enabled TV?Then there are three ways..
a) On the TV, go to network settings
b) From your router, check the DHCP table of the clients, if your TV is connected to your network, its IP should be listed.
c) Visit
IP-details.com and get the IP.
Find IP address
c) Visit
Why do i have to have the brightness set at 100% or you cant see the picture
HelloIf baklight CCFL tubes become weak, the brightness will be very weak. Now you can see the picture with least brighness. So it is sure that, the backlight inverter board is working well. Just check the CCFL lamps. For a 37 inch LCD tv may have atleast 14 CCFL lamps. When replacing, do replace all at one time. OK.
I have a LG dvd
player 5083 inserted the disc the correct way into the draw but the machine does not play the disc a very slight humming noise is heard then it spits the drawer back out
Clean the Lens: Use a DVD cleaning disc to clean the lens. If the problem persists, consider professional cleaning.
Test Other Discs: Try playing different DVDs to see if the issue occurs consistently. If it's specific to one disc, that disc might be the problem.
Check for Updates: Make sure your DVD player's firmware is updated. Refer to the manufacturer's instructions for firmware updates.
Try a Different TV: Connect your DVD player to a different TV to see if the noise disappears. If it does, the issue might be with your TV.
The hum is simply the player trying to read the disc. It can't so, it spits it out.
Remember that prolonged use of a malfunctioning DVD player could potentially cause damage. If the problem persists, consider seeking professional repair or replacement
