20 Most Recent
Wenger Swiss Military Alpine Diver Stainless Steel Water Resistant Swiss Military Alpine Diver Wenger Alpine Diver Black Dial w/ Stainless Steel Bracelet 70996 Watch for Men Questions & Answers
Need correct replacement battery
the watch movement deters which battery the watch needs it is very important you do not put a battery in that doesn't suit the watch as it can short out the circuit however you can get the correct size in a gold seal quality which should not leak, also the older the watch, the more demanding the watch becomes on the battery as the movement components start to experience wear and tear
Wenger Watch. I am looking for the right attachment that connects the wrist band.
Do you have a model number? Most watches use a spring loaded pin that slots through the strap at the watch end. The two pairs of 'legs' at each end of the watch have dimples on the inside flat surfaces that the spring pushes the ends of the pin into. You mount one end into a dimple then push against the spring until it's short enough to drop into the opposite dimple. A real pain in the tailbone to do as the bits are so small but you can do it yourself.
Battery for Wenger Terragraph watch model 010541106
If attempting to purchase the battery, please call a local watch store first (might be within a local mall). And then you can check websites like Amazon and ebay to attempt to find the battery for your watch.
Thank you.
