20 Most Recent
SMC Barricade Turbo Router Questions & Answers
How do I set up password protection for my SMC
Please follow the steps mentioned below and check if the issue is resolved.
- Please open a new browser window and in the address bar type in
'http://192.168.2.1' or 'http://192.168.2.1:80' or
'http://192.168.2.1:88' and press enter.
- The password would be either blank or smcadmin.
- To enable Encryption or Secure the Wireless Network, follow these steps:In the router's configuration
page:
Click on Advanced Setup -> Wireless -> Encryption.
- Select the Encryption type (WEP, WPA, WPA2 etc), type the Security Key and save the settings.(128-bit encryption uses 26 characters. Example: 01 2C 45 67 89 A0 CD
EF 01 23 45 6D F9
64-bit encryption uses 10 characters. Example:
01 A3 45 F7 8)
- The Wireless/Internet is Secured Now.
- You can also set the password for the Router log in: Please click on Administrator settings and input the new password.
Good Luck!
Thank you for contacting.
My router wont hook back to my laptop and i forgot the password
Go to your control panle then select network connections, if you see your wireless icon, right click it and try selecting repair first.
Also, if the wireless icon is in the lower right of the monitor, right click it and view wireless networks, look for you router, then select it. Then select connect.
Power problem
You would need a VOM (voltmeter) to check that the power adapter of your is giving out the necessary DC voltage to the router from the power plug. If yes and you have ruled out that it is not the power adapter nor the AC mains where it is plugged, try again but do a hard reset. If still a no go, it may be that your router developed a problem in its internal voltage regulation circuitry. Normally inside would be a fuse, a reverse protection diode and a 3 terminal voltage regulator whose output is 5VDC with some capacitors. You should check each that component is ok and proceed to check whatever you can inside the router. If 5VDC can be detected but there are no indicator lights, it may be that the chipset is fried. If this is the case, it may be to your advantage to replace the entire unit rather than do a component level repair. Pls be reminded of safety precautions when working with powered electronic devices.
This type of problem is caused by a strong power surge or near lightning strike.
If you are not comfortable opening the unit, perhaps you should seek the services of a qualified professional.
Hope this be of some idea/help. Post back how things turned up or should you need additional information.
Good luck and kind regards.
What are the Firewall options?
Uninstall and/or disable all proxy software (i.e., Internet Connection Sharing), firewall software (i.e., Norton Internet Security, Black ice, McAfee Antivirus, Zone Alarm) and also disable the built-in windows XP firewall in the PC's connected to the router.
I am unable to access the router's web interface.
* Check for restrictive Firewall settings.
* Clear the cache of your web browser.
* Try with a different web browser (e.g. Mozilla Firefox, Opera)
* Try to access the router from a different computer.
How do I configure my SMC router for a DSL Internet connection?
In the routers web interface -> Click on login (password would be either blank or smcadmin) -> Advanced setup -> WAN -> PPPoE -> Enter the following values:
* Type in the Username and the password provided by your ISP.
* Set MTU = 1440.
* Set maximum idle time to zero.
* Save the settings.
How do I Login to the Router?
Open a new browser window and in the address bar type in 'http://192.168.2.1' or 'http://192.168.2.1:80' or 'http://192.168.2.1:88' and press enter.
How do I power cycle the Modem and Router?
Power OFF the Cable/DSL Modem, then the Router and wait for couple of minutes. Now power ON the Cable/DSL Modem First, after the modem gets initialized, Power ON the router.
How do I clone the MAC address in a Router?
In the routers web interface, click on login (password would be either blank or smcadmin) -> Advanced setup -> click on WAN -> Dynamic IP address -> click on clone MAC address and save the settings.
