20 Most Recent
StarTech.com StarView SV411K 4-port KVM Switch Questions & Answers
I want to cancel my
This link explains how to cancel your AT&T service in detail.
http://www.ehow.com/how_5063699_cancel-at_t-phone-service.html
HAVE LOST MOVIE CHANNELS, ANYONE HAVE LATEST CODES
There have been no new codes for a long time (2008 i think)
The latest firmware can be downloaded from afterdawn or techkings.
If a full re scan does not get your channels back, Virgin has started to introduce Nagravision 3 in your area. This is being rolled out all over the country, there is no fix available, and from what i have read, there is not going to be any for this generation of eurovox/starview/digivox/arnet receivers
Have lost channels although I subscribe to a basis
Nope.
They are switching to nagravision 3 area by area. Once your area has switched, you can no longer get all the channels.
At this time no box can get around this , but from what i read, boxes with ethernet connections may be able to work, but no fixes are available yet.
Afterdawn and techkings has info on this
Starview 5 USB - cannot put in Codes
Did you get a piece of paper with it telling you how to download the files onto the usb stick. Then put it into the back of the box then scan the channels.You will also need the codes for your provider.
I have a Hp Laserjet p1505 printer. I installed
Using the Settings Feature on your operating system; you need to make certain the printer is listed and it the main printer to send data to. Check all settings and make certain, if using a wireless connection that the wireless settings are managed correctly. Generally, this is covered in the printer manual. For best results, get the FREE updates, and diagnostic programs from HP.COM.
My Saturn 2001 wagon start for 2-3 sec and turn off
Sounds like a fuel problem.... make sure the theft light is out.... happens when you get a new battery, key or keyfob and that is a dealer problem..... first check fuse for fuel pump, then fuel filter then last pump
