20 Most Recent
Sony KV-27S22 27" TV Questions & Answers
MARION TV NO SOUND BUT WE HAVE PICTURE
Hi Michael,
you can check the your colour system changed by mistakenly by yourself to go to setting and ,also try to re tune the channels or one channel.
if problem still there check the your tv has sound output socket or hedphone socket.
try with hedphones.
if not you must need to go to repair professional .if head phone working. it is a problem of your internal speaker or hedphone socket itself.
regards,
nuwan.
Tv works for about 2
If the sound continues normally and the screen goes black (no raster at all; the screen is totally dark) you have a high voltage problem. Usually, it is a failure of either the flyback autotransformer and/or the HOT.
The repair of this section is around $200 if you take it into a shop; about half that if you can do it by yourself.
However, be warned, there are over 100 parts in the high voltage and horizontal deflection section and any one of them can be the troublemaker. So, you really should diagnose it before making parts change outs even though 80% of the time it will be either the flyback or HOT.
The sound on my sony KV-27s22 comes on realy good
You definitely have bad solder joint.If you have a soldering iron you may be able to fix it.The way your talking it sound like in the deflection area.remove the back cover and start the set then using something non conductive i.e a wooden salad spoon , knock lighly around the circuit that way you may be able to pinpoint the area where the trouble is. you`ll have to pull out the chassis to resolder the joints.look for rings around solder spot. good luck
p.s; remove power before soldering
Tv repairing
You still have something open in power supply. Look for a fuse resistor or bad relay.
I NEED CODES FOR MY NEWSTAR NTR-B28Z FOR MY SONY TV
ChatGPT 3.5
User
I need code for newstar ntr b28z for my Sony tv
ChatGPT
Unfortunately, I can't provide specific code for your Sony TV remote without knowing the exact model number. However, you can usually find the code in the user manual of your Sony TV or by contacting Sony customer support. Alternatively, you can try using the auto-search feature on your newstar ntr b28z remote to find the correct code for your Sony TV.
User
ChatGPT
To find the code for your Sony TV using the Newstar NTR B28Z remote, you can try these general steps:
Turn on your Sony TV.
Press and hold the "TV" button on your Newstar remote until it blinks twice.
Enter the code for Sony TVs. Some common Sony TV codes are: 0000, 0011, 0080, 0111, 1234. If none of these work, you can proceed to the next step.
Press the "Power" button on the Newstar remote. If the TV turns off, the code is correct. If not, try a different code.
Once you've found the correct code, press the "TV" button again to lock it in.
If none of the provided codes work, you might need to consult the manual of your Newstar remote or contact their customer support for assistance.
