20 Most Recent
Sony KV-27S10 27" TV Questions & Answers
My 1994 27" sont KV27S10 blinks on and off. Any
How many times do these blinks occurs at one time switch ON? Count it. The blinks are fault indications, and are called blinking codes. If you wish to know more about these blinking codes, check the this link.
Pull up previous posts by its left sidebar, or type in the
brand name and model number to of your set, to its search box, and press '
Enter'
or view it in
Mosaic / Timeslide option.
Sony kv-27s10 has intermittent tuner issues.
This was a common problem with the Tuners of these models. The replacing of the Tuner should fix the Problem. You may be able to order it from Sony.
Here is their Customer Service Number.
1800-222-Sony
I hope this helps,
Skyassoc
Sony KV-27S10
is it vertical problem or retrace lines can you tell
Colour stain
Hi.
Yes it is A degause fault caused by either something magnetic being close to tv screen EG hifi speakers.
Or faulty degause thermistor, Or degause thermistor is not making good contact with pcb & only requires resoldering to pcb.
Allso try turning tv completely off at the mains switch leave a few hours then switch back on.
If you decide to take to A repair shop this repair is not expensive.
http://dysonmanuals.inc.io/
Chris..
Orion FTDV 2004 Dead Set
Question, when I clicked on this I clicked on a problem for a Sony KV27S10 but your text say's Orion, is it a Sony or a Orion?
I NEED CODES FOR MY NEWSTAR NTR-B28Z FOR MY SONY TV
ChatGPT 3.5
User
I need code for newstar ntr b28z for my Sony tv
ChatGPT
Unfortunately, I can't provide specific code for your Sony TV remote without knowing the exact model number. However, you can usually find the code in the user manual of your Sony TV or by contacting Sony customer support. Alternatively, you can try using the auto-search feature on your newstar ntr b28z remote to find the correct code for your Sony TV.
User
ChatGPT
To find the code for your Sony TV using the Newstar NTR B28Z remote, you can try these general steps:
Turn on your Sony TV.
Press and hold the "TV" button on your Newstar remote until it blinks twice.
Enter the code for Sony TVs. Some common Sony TV codes are: 0000, 0011, 0080, 0111, 1234. If none of these work, you can proceed to the next step.
Press the "Power" button on the Newstar remote. If the TV turns off, the code is correct. If not, try a different code.
Once you've found the correct code, press the "TV" button again to lock it in.
If none of the provided codes work, you might need to consult the manual of your Newstar remote or contact their customer support for assistance.
